Thread: Command Line Disappeared
    2005-07
    2
    Default Command Line Disappeared
    The command line in AutoCAD Lt on one of our computers has disappeared. I've looked behind toolbars, moved toolbars and gone through the options and can't find it. F2 brings up the window, but that can't be docked.
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Command Line Disappeared
    Which version are you using?
    Earth
    9,805
    Quote Originally Posted by dtbosso
    Thanks
    Try the procedure documented here [ http://www.dotsoft.com/acadtips.htm ] (Scroll down about 1/3 of the way). It's for AutoCAD, but I'm sure the reg entries are close.
    R.K. McSwain | CAD Panacea |
    2005-07
    2
    Quote Originally Posted by rkmcswain
    Thanks, that was it.
  1. 2014: Command Line has disappeared - PLEASE HELP
    By Civil_Sarah in forum AutoCAD Civil 3D - General
    Last Post: 2015-04-27, 07:03 PM
  2. Command Line has disappeared?
    By KC Bell in forum AutoCAD General
    Last Post: 2015-02-06, 03:01 PM
  3. 2015: Command Line Disappeared
    By spose in forum AutoCAD LT - General
    Last Post: 2014-09-24, 08:00 PM
  4. 2012: MEP command panels disappeared
    By Mikeyspeed in forum AMEP General
    Last Post: 2012-01-25, 09:34 PM
  5. Onscreen pulldowns while in a command have disappeared...
    By cwjean76 in forum AutoCAD General
    Last Post: 2009-06-08, 05:43 PM
