Thread: Reloading Express Tools menu in AutoCAD 2006
    I could stop if I wanted to Haden's Avatar
    2004-05
    St. Louis, Missouri
    292
    Default Reloading Express Tools menu in AutoCAD 2006
    My install of AutoCAD 2006 had been working fine, but when I opened it at home tonight, it was not finding the proper utilities when I clicked on a button on the Expresstools toolbar. I went to the menuload dialog, unloaded the expresstools, and now I can't find where the expresstools menu resides so that I can reload it. I searched my C drive for files that contain *expr*.mn*, but they must have changed the type of file the menus are stored in. I know the whole .cui file is a new concept, but I have been a converted dyed-in-the-wool Revit user lately, so my AutoCAD customization knowledge is a couple of versions out-of-date.
    Any help here would be GREATLY appreciated, as I would rather not have to reinstall AutoCAD 2006 all over again.
    2004-05
    St. Louis, Missouri
    292
    Default Re: Reloading Express Tools menu in AutoCAD 2006
    I found it at: C:\Documents and Settings\<Login Name>\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Support\acetmain.mnl. Hopefully, that will do me for now.
    2001-12
    St. Louis
    5,406
    Talking Re: Reloading Express Tools menu in AutoCAD 2006
    Quote Originally Posted by hadens
    Thanks for posting back where you found that. I'm sure someone will find the info useful.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    I could stop if I wanted to Steve Johnson's Avatar
    2004-11
    Western Australia
    294
    Actually, you can usually restore the Express menu by typing in the EXPRESSMENU command. Also, the acetmain.mnl file is the LISP associated with the actual menu file acetmain.cui. You need to select the latter if you are using MENULOAD or CUILOAD to restore the Express menu manually.
    2004-05
    St. Louis, Missouri
    292
    Quote Originally Posted by steve.johnson
    I couldn't remember which of tie acetmain.* files I used to reload it when I fixed it, so thanks for the clarification. It's good to know the different file extensions, since I was used to *.mns and *.mnc back when I did customization in version 2000i. I also will remember now that "acetmain" means AutoCad Express Tools main.
    Thanks again for the clarifications.
  1. AutoCAD 2007 can not locate Express Tools pulldown menu
    By amasella in forum AutoCAD General
    Last Post: 2007-01-19, 07:49 AM
  2. Layers menu on AutoCAD 2007's Express Tools
    By rysning81 in forum AutoCAD General
    Last Post: 2006-08-11, 12:09 AM
  3. AutoCAD 2007 Express Tools menu missing
    By ed.wiper in forum AutoCAD General
    Last Post: 2006-06-15, 02:34 PM
  4. Express Tools menu does not show up in AutoCAD 2006
    By sampsonpatricia in forum AutoCAD General
    Last Post: 2006-06-13, 08:51 PM
  5. Where are the Express Tools (AutoCAD 2006)
    By del.wingerter in forum AutoCAD General
    Last Post: 2006-01-25, 08:00 PM
