Results 1 to 10 of 12
Thread: Changing layer names
    100 Club Matt Mercer's Avatar
    2004-05
    Liberty Lake, WA
    147
    Question Changing layer names
    A general question about changing layer names to different layer names. I was wondering if anyone has a lisp routine that they are willing to share that changes a certain layer name to a different layer name, Obvious I would have to modify the lisp routine to fit the names I use. Thanks for any input. Matt
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Changing layer names
    Quote Originally Posted by MATT_MERCER_2000
    Have you tried the Layer Translator within AutoCAD?
    2005-08
    1,043
    (vla-put-Name
     (vla-Item
      (vla-get-Layers
       (vla-get-ActiveDocument
        (vlax-get-Acad-Object)
      "Layer1" ; Old layer name
     "HappyTest" ; New layer name
    Will error if old layer name doesn't exist, or if new layer name alread exist, but shows you how to do it. If you don't already have it loading, you will have to add
    (vl-load-com)
    So that you can use the ActiveX controls in lisp.
    2004-05
    Liberty Lake, WA
    147
    Thanks - I can't wait to try it out.
    Matt
    2004-12
    153
    you can also use the RENAME command
    2004-05
    Liberty Lake, WA
    147
    Thanks CiphDRMRS - This is what I've wanted. I do have a problem with it. I was wondering if there is a way around it. Lets say I have a couple of layers that are from a client that I want to name the same - It will not allow me to do that I get this error message." ; error: Automation Error. Duplicate record name"
    any suggustions?
    Matt
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    You could rename the matching layers to a similar name like adding a 01, 02 to the end of the layername and then use the layer merge express tool to combine them.
    It is possible to search through each of the blocks collection of and iterate through each item and change the layer names to merge them yourself. The only difficulty is compound objects like normal weight polylines and blocks with attributes. Special attention needs to be paid to these objects, especially the seqend object which must be accessed though using entnext from the block entity or pline entity.
    Hope this helps.
    Peter Jamtgaard
    2004-05
    Liberty Lake, WA
    147
    Thanks that does seem to work, with the lisp routine and layer merge tool - its going to be a lot faster now, I still wish there was a way of eliminating the express tool in the lisp routine - but I'm not going to complain because its again a lot faster than the old way.
    Thanks for everyone who responded.
    Matt
    2005-08
    1,043
    If you don't want to use the Express tool, then you will have to write the code yourself. It might be hard, but could also be a great learning project. Maybe just work on it when you have time, and until you finish it use the ET one.
    Glad you got something that works for you.
    2004-05
    Liberty Lake, WA
    147
    Question Re: Changing layer names
    ; error: Automation Error. Key not found
    Does anyone know what this means?
  1. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  2. Replies: 6
    Last Post: 2007-05-30, 02:02 PM
  3. Replies: 2
    Last Post: 2007-01-09, 06:39 AM
  4. Replies: 4
    Last Post: 2006-12-11, 06:34 PM
  5. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
