Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: An easy way to make Revit wall joins drive you insane
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,343
    Default
    Insert a column. Now take a wall at least than twice as wide as the column and drag it to the edge of the column -- the wall eats the column!
    But wait - there's more...
    Now take a curtain wall and end it against the column -- that works fine. But then drag the wall that's 2x the width of the column and everything goes to pot.
    I STILL find Revit's wall joins way too reactive. I think others have also wished that there was some sort of toggle you could activate to allow/disallow joins at wall ends. Or a wall join tool: the rest of the time walls would just stop where you dragged them.
    Thoughts or workarounds anyone? I tried an in-place void to cut the end off the thick wall to expose the column, but that's a bit brutal...
    Wes Macaulay LEED AP
    Teck Construction LLP
    Revit 2014 x64 | Win7 x64 | nVidia GT 650M
    Tell Adesk what you think!
    2002-02
    St. Louis, MO
    4,688
    Default Re: An easy way to make Revit wall joins drive you insane
    Why are you putting a column in a wall?
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2003-08
    Vancouver, BC Canada
    3,390
    Aaron,
    I think Wes is taking up the cause I brought up in this post
    http://www.zoogdesign.com/forums/php...pic.php?t=3298
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    I could stop if I wanted to rhys's Avatar
    2003-05
    Cotswolds, UK
    433
    I assume we're talking Architectural columns here, seems fine with structural columns.
    Also works with one wall but yes, if two walls meet the column then they join. I can't imagine exactly what you are trtying to achieve, but if the wall is twice as thick as the colum perhaps drawing as two walls would achieve what you want.
    2003-08
    3,390
    Rhys,
    Take a look at the images I posted in the other thread. The walls are in line, not meeting at a corner as you have shown. The exterior wall happens to be a masonry rain screen wall that also has a masonry finish on the interior, hence the excessive thickness.
    I tried this with architectural columns, structural columns and, as is the case in the project, an in place family with a 'column' family category. If you make the changes in a specific sequence (insert/create column, align the brick to one column face, drag the curtain wall control ppint to the other column face) it seems to stick... until you make any changes to the walls. Then they snap back together.
    BIMblog.ca
    2003-05
    3,343
    The wall-ending-at-a-column with a curtain wall on the other side is a common feature in "west coast style" architecture such as we have out here in the Pacific Northwest. This post and beam style is very common: roof loads are transferred to columns, and walls are infilled between the columns.
    I've got a couple of clients in mind who are beginning to use Revit and so when Dimitri found this one out, I needed to come up with a solution before I get the question.
    I'm not at all happy with Revit's behaviour as mentioned above -- this is another problem that comes from hyperactive wall joins.
    Even though I'm griping I'm still smiling. At least I've got a workaround! And Revit still makes me happy. And ADT <choke! thud!>
    2003-09
    Melbourne
    144
    Just on the general subject of wall joins, we do quite a few tilt-up conc. panel walls. The panel joints are usually about 15mm and we have recessed vertical or horizontal "grooves" as decorative elements. The "grooves" when horizontal are easy enough to do by using a compound wall and adding in reveals. Verticals are a little harder but the main problem we have is in trying to get the 15mm joint between the panels. The panels when set to a 150mm thick conc. wall seem to want to join to each other all the time. Using "disjoin" does absolutely nothing.
    I might be missing something but this wall joining, for me, is also just too automatic. Is the "disjoin" feature supposed to be used in this type of situation or not ?
    2003-05
    5,153
    Quote Originally Posted by PaulB
    Just an idea on tilt up ( which I haven't explored ).
    Could you use a curtain wall, with the system panels being the tilt-up and the "mullions" being invisible and 15 mm wide ?
    Just an idea.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    100 Club ShaunV's Avatar
    2003-08
    JHB South Africa
    105
    Use structural columns! that way they interact as they should do. I find columns in modeling useless due to the fact they get eaten by the wall. I used a 200 x 200 Structural column in a 800 thk wall to test no prob.
    Shaun van Rooyen
    Cadplan JHB
    Authorised Autodesk Systems Centre
    South Africa
    2003-04
    Irvine, CA
    6,770
    Structural columns are intended to model the structure of a building and architectural (Revit term) columns are intended to get "swallowed" by a wall and further they are meant to reflect a built up condition "around" a colum that otherwise wouldn't "fit" in a wall. Use the right "tool" for the task...
  1. Managing wall joins in Revit
    By Wes Macaulay in forum Revit Architecture - Tips & Tricks
    Last Post: 2011-12-01, 02:25 AM
  2. Revit 2009 - Onscreen Wall Joins
    By steve.70285 in forum Revit Architecture - General
    Last Post: 2008-04-18, 03:18 PM
  3. Revit to Max- Dreaded wall joins
    By pfschuyler in forum 3ds Max - General
    Last Post: 2007-09-13, 01:50 PM
  4. Make Plotting easy in AutoCAD LT 2007
    By jaredf in forum AutoCAD LT - General
    Last Post: 2006-07-18, 12:09 AM
