Thread: "Select Objects" options
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default "Select Objects" options
    There are many options for selecting objects. All of these options are generally available for every command that displays a "Select objects:" prompt. You can type "?" (a question mark) at the prompt to see all the options. A complete description of each option is given in the Autocad help for the "SELECT" command.
    The highlights:
    • Type WP to use a "Window Polygon" to select. This lets you draw an irregularly-shaped area, and all objects that are completely inside the polygon are selected.
    • Type CP to use a "Crossing Polygon" to select. Similar to a Window Polygon, except it also selects all items that are crossing the edge of the polygon, even if they aren't completely contained inside the polygon.
    • Type F to use a "Fence" to select. You are prompted to draw a polyline, and all items touching the polyline are selected.
    Also note that you can type R to switch to "Remove" mode. This works kind of like holding down the SHIFT key, except it lets you use the other options to remove items from a selection set. So, for example, you can select all objects in an entire area. Then hit "R" to switch to "Remove" mode, and then use a Fence selection to remove certain items from your selection set. Typing A will return you to "Add" mode.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Default Re: "Select Objects" options
    This is a good tip. I am not quite sure what I would use it for.
    I am guessing that you can select objects in an L shape pattern.
    I could stop if I wanted to andy.manninen's Avatar
    2005-12
    @ _ork
    304
    These are great for trimming and extending! Selectivity is key! Thanks!
    Andrew Manninen
    CAD Manager
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
    2004-02
    Colorado
    1,986
    Quote Originally Posted by Robert.Hall
    Knowledge of these options can come in handy very frequently.
    For example, ever need to select a bunch of objects along side a road that runs diagonally up the screen, but that rectangular selection box goes the wrong way? Well, use a Fence or Polygon Selection. Much better than selecting them all one at a time, or using a series of long, narrow rectangular selections, or applying a DV-TWIST just to select some objects.
    In short, these options come in very handy for picking objects out of a cluster, and only selecting the ones you want, without having to click on a bunch of objects individually.
    I could stop if I wanted to de-co1's Avatar
    2005-07
    Jhb - ZA
    265
    I do like these hotkeys. It does frustrate me to no ends when I see a user picking loads of individual items surrounding something they want, instead of simply removing that selection... trimming and extending too...
    David
    "Artists to my mind are the real architects of change, and not the political legislators who implement change after the fact."
    William S Burroughs
  1. Family Question - "automatically" select embedded families?
    By Super T in forum Revit MEP - Families
    Last Post: 2011-07-26, 08:50 PM
  2. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum Español - AutoCAD Civil 3D
    Last Post: 2009-02-01, 03:21 AM
  3. Solview and select "ortho" does not generate correct view
    By Spectrefish in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-01-20, 07:57 AM
  4. Printing "Print Range" Select sheets problem?
    By jmarlovits in forum Revit Architecture - General
    Last Post: 2005-02-22, 08:27 PM
  5. Design Options Visibility "Automatic" v. "Pri
    By narlee in forum Revit Architecture - General
    Last Post: 2004-03-27, 05:16 AM
