Results 1 to 10 of 11
Thread: Super Noob Wall Question
    2004-08
    19
    Default Super Noob Wall Question
    This is a ridiculously easy question but i just can't seem to get it to work. Here's the problem,(I'm almost embarassed to ask.)
    I have a simple generic wall the stands 3'-0" high. I want to view this wall in plan showing a cut at 1'-6" so I can see what the wall is made of. What are the proper view range settings? I tried a dozen different combinations and nothing worked, i keep seeing the top of the wall and not a cut at 1'-6".
    Please help me before a jump of a roof, =(.
    All AUGI, all the time jbalding48677's Avatar
    2003-05
    Irvine, CA
    765
    Default Re: Super Noob Wall Question
    Check out plan regions...
    - JB
    2004-08
    19
    Tried it, still doesn't work. The wall is 3'-0" high. I set my view range setting as follow:
    Top Clip Plane : 4'-0"
    Cut Plane: 2'-0"
    Bottom Clip Plane: 0'-0"
    View Depth: 0'-0"
    With these setting it should cut the 3'-0" high wall at 2'-0" above the level, but it doesn't. It just shows the wall in plan as being viewed from above.
    Same thing with Plane Regions.
    Active Member david_spehar's Avatar
    Cleveland, Ohio
    98
    It looks like all of your view settings are correct to see a 3'-0" high wall cut at 2'-0" above the associated level. Check your wall settings to make sure it is in fact set with a 0'-0" offset from the level and its unconnected height is 3'-0". Or, draw a full height wall from the associated level to the next level to make sure you see it correctly. If so, change its properties to unconnected and a 3'-0" height. That's my 2 cents (if that doesn't work I would definitely jump)
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Hmm...I think the problem is that it is too low to be cut...there is a "flaw" if I may say, where something cut below a certain height (I think 4', I can't remember) will not show properly cut.
    Can somebody back me up with this?
    Luigi
    2015-11
    Royal oak, Michigan
    1,513
    If you are able to make the wall full height (above 4') and then cause the height of the wall to automatically be 3' (i.e. changing the profile of the wall, or attached to roof {which won't help you in this situation, but maybe in another}, etc.)
    I believe that when you cut it at 1'6", it will show properly....
    (I am going with my gut on this...I didn't verify it, but kinda remember this solution)
    Peace,
    I could stop if I wanted to Clyne Curtis's Avatar
    2003-05
    Provo, Utah
    208
    Are your detail settings set higher than coarse?
    Clyne
    2004-08
    19
    That was the first thing a checked when I encountered the problem, they're on "fine" and the problem is still there.
    2004-08
    19
    Well I extended this wall to the level above and then used a negative offset to bring the wall back down to a physical height of 3'-0".
    Then it worked.
    This is my "wish list" item for the day. I hope it gets fixed. Thanks for the help guys.=)
    2001-12
    Irvine, CA
    7,567
    Assigning the wall to the level above and using the negative offset is THE way to do this. By design short walls below the cut-plane will always show as projection. You get around this by "fooling" Revit as you have done.
  1. 2013: Super NOOB here
    By NickD22 in forum Revit MEP - General
    Last Post: 2013-02-25, 07:58 PM
  2. noob question about Families
    By kevin681396 in forum Revit MEP - Families
    Last Post: 2011-02-28, 01:36 PM
  3. Noob Question on setting elevations
    By jamesm in forum AutoCAD General
    Last Post: 2009-04-01, 11:39 AM
  4. Warning! Retreaded Noob question...
    By crbateman in forum AutoLISP
    Last Post: 2009-03-18, 02:54 PM
  5. VBA NooB Question
    By caddog71 in forum VBA/COM Interop
    Last Post: 2008-01-25, 05:43 PM
