This morning I'm working on a DP drawing set where I have a context plan showing our building overlaid on an aerial photo. The topo model spills over the prop lines so I used the crop region to clip it back, but of course the whole aerial photo shows up, which in this case is just great.
To crop the photo earlier I used a filled region, but in 8.1 you can't clip the filled region or it will simply disappear completely, and you'll see the entire image.
I don't like how images are considered symbolic: they are always the same print dimensions. So change the scale of the view and you have to change the size of the image! It would be nice to have the option of setting the size of the image against the model (real-world dimensions) OR against the sheet (as it is now).
