Thread: Created PDF cuts off 1/3 drawing
    2004-05
    Custer, Washington
    77
    Default Created PDF cuts off 1/3 drawing
    Hi:
    Here's my problem. I have acad 2005 running Windows XP, When I create a PDF with PDF995 The top 1/3 of my drawing is cut off. The strangest thing is it only occurs on this one job I am working on, every other job it comes out fine. This is a 24" x 36" dwg, but if I half size it, it comes out fine. By the way 90% of our drawings are 24" x 36" and I've never had this problem. Also I am plotting on a hp design jet 1050c plus. Any ideas? I'm going mental!
    Thanks
    2001-03
    13,499
    Question Re: Created PDF cuts off 1/3 drawing
    Quote Originally Posted by kimlance
    Hi
    Do the drawing files in question Plot ok! to the above output device, or do you experience the same problem as outputting to PDF ?
    Plus, the following thread might help...
    Plot Preview - bottom half of drawing missing
    Have a good one, Mike
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Default Re: Created PDF cuts off 1/3 drawing
    I have have a similar issue at times. My work around is to print to a dwf first, and then
    print the PDF. Seems like a pain, but it gets the job done.
    2004-05
    Custer, Washington
    77
    Drawings look fine in preview & plot fine when plotting as a dwg. I've gone through all the procedure's & everything checks out o.k. What I ended up doing was create the pdf at half size & that seemed to work but that was a bit of a pain (time consuming). I'm beginning to think it has something to do with the program the architect is using because it is not acad. Anyhow thanks for the input. I will chalk it up to one of those great mysteries I will never figure out. ha ha. Also have you guys noticed if many people are using dwf to share drawings, I haven't, but it sure seems alot easier. Thanks again and Robert we do golf in the snow, we just use colored balls.
  1. Drawing created with more recent version of CAD
    By dzatto in forum Project Navigator
    Last Post: 2009-10-28, 02:31 PM
  2. Copy from a drawing created in an educational version?
    By cabeaton in forum AutoCAD General
    Last Post: 2008-10-17, 06:19 PM
  3. Does AutoCAD store who created drawing in Database?
    By akasten in forum AutoCAD General
    Last Post: 2006-06-22, 10:04 AM
  4. Is there any way to determine who created a drawing?
    By nwnuk in forum AutoCAD General
    Last Post: 2006-05-03, 02:53 AM
  5. Replies: 2
    Last Post: 2005-12-15, 07:48 PM
