Thread: Roof question - Gable end roof eaves
    2005-12
    Hartford, CT
    394
    Default Roof question - Gable end roof eaves
    I am having some trouble modeling the roof eaves on the gable end of a sloped roof. The roof structure for the building is 10" framing with 3/4" plywood sheathing. Typically roof eaves are scabbed onto the gable end wall, and are usually framed with much smaller material. In my case the eave needs to over hang the end wall by 6", and is going to be framed out of 6" light Gauge framing.
    What would be the best way to model this? Right now I am stopping the main roof (10" thick) at the gable end with no over hang. I then created a separate 6" thick roof for the eave. I then used the join roofs command.
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    Default Re: Roof question - Gable end roof eaves
    i'd either do that, or make a facia profile that is really wide
    2005-12
    Hartford, CT
    394
    Quote Originally Posted by janunson
    I thought of the facia idea, but when I cut wall and building sections I want the model to accurate.
    2005-05
    TX
    447
    The two roofs will make it appear about as correct as you will be able to get it shown in your sections. You will need some drafting lines to show the scab. Or, you are probably looking at modeling all the framing with extrusions.
    2005-12
    Hartford, CT
    394
    Quote Originally Posted by BWG
    I am not planning on modeling the framing. I will just use drafting lines to fill in the blanks.
  1. Roof with flare at eaves - How would YOU do it?
    By 3dway in forum Revit Architecture - General
    Last Post: 2013-08-04, 07:59 AM
  2. ROOF EAVES
    By lezopera402465 in forum Revit Architecture - Families
    Last Post: 2011-10-13, 06:38 PM
  3. join gable roof with polygon 5 sides roof
    By o_dragos in forum Revit Architecture - General
    Last Post: 2010-11-14, 04:17 PM
  4. Gable roof to Gable roof issue and walls
    By Matt Mercer in forum Revit Architecture - General
    Last Post: 2005-12-31, 10:48 PM
  5. Gable Roof Question
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2005-01-19, 06:05 PM
