Results 1 to 7 of 7
Thread: Rendering autocad 3d blocks?
    2004-07
    179
    Default Rendering autocad 3d blocks?
    Hello everyone,
    I was trying to import an autocad 3d block to revit with the materials assigned in autocad itself but when i render the same block in revit i don't see all the materials i have selected.in autocad.
    why does this happen? and is there a solution where we can keep the materials intact or else have the materials assigned in autocad.?
    Regards,
    Aliya
    I could stop if I wanted to Mike Hardy-Brown's Avatar
    Melbourne, Australia
    282
    Default Re: Rendering autocad 3d blocks?
    Aliya,
    Have you checked the object styles?
    As far as I can remember, you might only be able to change the colours only.....
    2004-07
    179
    Quote Originally Posted by Mike Hardy-Brown
    Aliya,
    Thanx Mike
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    If I understand what's being asked... generally speaking, you just need to remap them. In revit, you can map the autocad object "layers" to materials in your library using object styles. You'll probably also need to go through your materials and sort them out for the imported dwg so you have something to map to in the object style properties.
    To avoid doing this every time you need to use the same dwg, I generally insert it into a new family, work out all the material mapping and save - then load it into my project.
    Hope that helps.
    2006-01
    4,516
    Aliya, ive been doing this with AutoCAD vehicles, for my rendering... And ive had to import tha material maps/files, or whatever, in to the same directory as my Revit material library, so accurender could find it when i went to assign them...
    282
    First prize would be to take your ACad Dwg into a new RPC Car family and apply the RPC properties to it, therefore you will have more of a "photorealistic render."
    This is where the 3d Max / Viz renders experts/users Knock accurender
    2006-01
    4,516
    Woah, i didnt even see RPC family in there. I think i should try that too, as my way of importing the materials in to my material library is working, but it makes the cars very metallic and reflective... Like chrome, lol...
  1. Network Rendering en AutoCAD ???
    By JR in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2010-06-23, 10:39 PM
  2. 3D Rendering done in AutoCAD 2006
    By harilalmn in forum AutoCAD Gallery
    Last Post: 2006-12-15, 05:30 PM
  3. Farewell to AutoCAD Rendering
    By arshiel88 in forum AutoCAD Gallery
    Last Post: 2006-11-02, 03:50 PM
  4. Creating 3D rendering in AutoCAD
    By Detsenira in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-02-23, 02:22 AM
  5. Rendering in AutoCad
    By tom_ola in forum ATP Course Wishlist
    Last Post: 2005-11-16, 06:44 AM
