Results 1 to 7 of 7
Thread: a room tag that will show "room length x room width"
    2005-04
    Dhaka, Bangladesh
    2
    Default a room tag that will show "room length x room width"
    is it possible to make a room tag that will show "room length x room width"?
    any suggestion will be appreciated.
    Bayejid
    2002-12
    695
    Default Re: a room tag that will show "room length x room width"
    No - absolutely not. Perhaps Revit 9?
    All AUGI, all the time Arnel Aguel's Avatar
    2003-05
    Philippines
    577
    If I remember correctly there was a thread about this few years back where the factory explained that will be difficult because not all rooms are rectangular what will happen if you have irregular shape room what will be the rules in getting the length and width of the room.
    2001-07
    Phoenix, AZ
    1,003
    Quote Originally Posted by Arnel Aguel
    just do what ADT does and report the length and width of the bounding box... it ain't perfect but it ain't bad either...
    2002-02
    St. Louis, MO
    4,695
    Quote Originally Posted by greg.mcdowell
    ...until your client finds out his room isn't 14', but really 11'-6"
    100 Club anthony.67953's Avatar
    2004-05
    Boone, NC
    145
    I posted this as a wish list item - where you would pick the walls
    2005-10
    36
    You can always add a parameter to the Room Tag that would let you manually add the Room Length and Width for each room but this can not be done automatically. You might consider controling the visibility for this parameter so that you can turn off for other plans types. I currently use one room tag that displays differently preliminary pricing plans, DD's and CD's all buy controlling the visibility. Nice thing about it, you do not need to re-type the name of the room
    Ken Marcus
    RFI Consultants
  1. "Room Object and Reference Lines" no longer print?
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2012-01-10, 05:10 PM
  2. "Auto" Generate Walls from Room Seperator lines
    By ra in forum Revit Architecture - General
    Last Post: 2009-06-11, 02:16 PM
  3. How to show the "level" name in a room tag?!
    By samov in forum Revit Architecture - Families
    Last Post: 2009-03-18, 09:22 PM
  4. room number will not show up on room tag
    By jordannw in forum Revit Architecture - General
    Last Post: 2007-12-28, 05:41 PM
  5. Show Length and Width of Room
    By roy.70844 in forum Revit Architecture - General
    Last Post: 2005-04-11, 03:48 PM
