Thread: Auto Adjusting Closet Door & Coat Rod
    2004-01
    North America
    18
    Default
    Anyone know how to create a family parameter that adjusts automatically instead of by instance.
    I have closets of varying sizes and it would be nice to have a coat rod that adjusts automatically to the width of a closet.
    Additionally, I'd like a sliding closet door to adjust to the same closet width.
    This would eliminate the neet to edit the length of each these family instances.
    Any ideas?
    2003-05
    5,153
    Default Re: Auto Adjusting Closet Door & Coat Rod
    Read up on nested families.
    Create the door and the rod as separate families and then nest them in the parent family, passing the parameters for the robe length, door opening to the parent family.
    All AUGI, all the time ajayholland's Avatar
    2003-04
    Sunny Southern California
    505
    I don't see the possibility of making them adjust automatically, but you might take a look at how some other instance-adjustable families are constructed. (I'm thinking of countertops, plywood segments, curbs, etc.) Instead of assigning the length parametrically, you'll use the align tool to adjust the edges to other reference planes.
    ~AJH
    2003-05
    5,153
    You could make a type catalogue of the closet sizes you want, and add your doors and rod as parametric elements in the family, locked to the closet length.
  1. 2014: adjusting the wall opening in door family
    By vanderloo5 in forum Revit Architecture - Families
    Last Post: 2013-10-24, 04:39 PM
  2. adjusting door display
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2008-12-20, 06:32 PM
  3. adjusting position of revoling door
    By ablood in forum Revit Architecture - General
    Last Post: 2007-08-17, 12:32 AM
  4. Door Tag auto alignment with the door?
    By ron.sanpedro in forum Revit Architecture - Families
    Last Post: 2007-06-18, 07:36 PM
  5. Sliding-Closet Door
    By Steven Campbell in forum Revit Architecture - Families
    Last Post: 2004-02-18, 11:04 PM
