Thread: How do you insert a Table style into Tool Palette
    2005-02
    54
    Question How do you insert a Table style into Tool Palette
    How do you insert a table style into tool palette?
    13,656
    Default Re: How do you insert a Table style into Tool Palette
    Hi
    See if this thread ( Table From Tool Palette ) from the Autodesk Discussion Groups helps...
    Have a good one, Mike
    2005-02
    54
    Question Re: How do you insert a Table style into Tool Palette
    Thanks Mike for the link.
    Now I have a new problem with my tables. They are coming in at;
    SCALE X: 0.08
    SCALE Y: 0.08
    SCALE Z: 0.08
    So I change the scale to 1, the tables are at the right scale. After explode them again, then they scale up. Explain, text so set to 0.09 but after exploding, 0.18.
    TP:
    SCALE: 1.0
    AUXILIARY SCALE: NONE
    EXPLODE: YES
    I don't know about this. Any ideas out there?
  1. Table Properties from Tool Palette
    By jwoodswahl in forum AutoCAD General
    Last Post: 2011-11-28, 11:25 PM
  2. Replies: 3
    Last Post: 2008-10-09, 02:05 PM
  3. Insert a Block from a Tool Palette
    By chris.kulhanek in forum AutoCAD Customization
    Last Post: 2006-07-10, 10:57 PM
  4. Insert a block from a Tool Palette and pre-specify Attribute value
    By andy.89024 in forum AutoCAD Customization
    Last Post: 2006-05-09, 10:46 AM
  5. Tool Palette Symbols - Insert Dimscale problem
    By Doodlemusmaximus in forum AutoCAD Customization
    Last Post: 2005-12-05, 12:16 AM
