Results 1 to 6 of 6
Thread: AutoCAD 2006 - Running OSnaps seem slow, magnet seems stronger
    Montana
    26
    Cool AutoCAD 2006 - Running OSnaps seem slow, magnet seems stronger
    This is alittle annoying. Using Autocad 2002 with osnaps on you could move the cursor fast over alot of lines etc without it just stopping at the first endpoint, intersection etc. Now with the new 2006 Autocad its like there is a super strong magnet that just stops everything.. Yes I use F3 all the time to toggle but sometimes I forget and when I realize it has stopped midstream it sucks. Makes the drafting more of a pain. Is there a setting somewhere to help me out?? The magnet toggle does not seem to help at all.
    Thanks
    13,656
    Default Re: AutoCAD 2006 - Running OSnaps seem slow, magnet seems stronger
    Hi
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    First guess...
    Look at the new "Visual Effects" settings and "Selection Preview" options.
    Have a good one, Mike
    2001-12
    St. Louis
    5,407
    Talking Re: AutoCAD 2006 - Running OSnaps seem slow, magnet seems stronger
    Quote Originally Posted by awiebe
    Thanks
    just read a tip on Lynn Allen's blog about increasing/decreasing the magnetic strength of osnaps. hope that helps.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Montana
    26
    Cool Re: AutoCAD 2006 - Running OSnaps seem slow, magnet seems stronger
    Thanks to those responding to my question. I guess the use of the word magnets wasn't quite right. The problem happens when I am zoomed out a bit and then do an inquiry, angles,NE something like that. Well lets just say when I forget to hit F3 and I am trying to move the cursor it hits an osnap object... end, int, node, whatever and sits there for what seems like forever, 2-4 seconds, releases and then finds another thing to check out before I know it, I cuss then I remember to hit F3 and I'm cruising again. Any suggestions thoughts appreciated.
    2004-10
    15
    Have you tried using the "Nearest" running Osnap along with the ones you usually use?
    I find that having the nearest box checked stops the snaps from jumping around as I move over the drawing. You may also try changing the size of your pickbox to see if that weakens the magnet effect.
  1. AutoCAD LT 2007 with SP2 applied, appears to be running slow
    By larry.111254 in forum AutoCAD LT - General
    Last Post: 2007-05-09, 10:57 AM
  2. AutoCAD running slow on HP intel core 2 duo E6600
    By kwong in forum AutoCAD General
    Last Post: 2007-04-11, 10:51 PM
  3. Autocad running really slow on Network
    By tim.101799 in forum AutoCAD General
    Last Post: 2007-04-05, 12:34 AM
  4. LT 2006 running very slow on Windows XP SP2
    By briand.87290 in forum AutoCAD LT - General
    Last Post: 2006-05-03, 11:11 AM
  5. Running Map 3D 2006 as AutoCAD 2006
    By paul.lloydsmith in forum AutoCAD Map 3D - General
    Last Post: 2005-08-25, 04:55 PM
