Thread: Modelspace vs Paperspace
    2005-09
    4
    Default Modelspace vs Paperspace
    I have been using Autocad since release 10, however i have never learned how to use the paper space window, I just draw in the model space window, and I ignore the paper space window. I know there are some very good uses for the paper space window but, where do I go to find information on how to use this feature? I would gladly hear any suggestions.
    0,0,0 The Origin
    8,569
    Default Re: Modelspace vs Paperspace
    Hi there.
    First, follow the links listed in the "similar threads" box at the bottom of this page (the first four anyway).
    The basic premise is that the geometry (your "model" - 2d or 3d) goes in modelspace and everything else goes in paperspace. Depending on your industry and/or method of working, it is arguable in which space your dimensions go. See what works for you but I believe the general trend is more and more towards putting them in paperspace.
    HTH
    John B
    13,625
    Hi
    Plus here are some additional threads that contain information about Paperspace Tutorials...
    model-layout
    Plot -vs Print
    Online tutorials, learning Cd's, books
    Need Paper space tutorial
    Modelspace and Paperspace training and tutorials
    Have a good one, Mike
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    this office was in same boat till late last summer, we xref'd EVERYTHING (within reason). I updated our dept. standards to implement SSM, and it has gone a lot smoother than i had anticipated. we dim and note in paperspace.
    use the 'view window' copiously in your model files, (preferably using your view titles to name them), and placement onto sheets should be a breeze!
    set a view for the whole model! if you have RCP layered into your base plan for example, the layer settings can also be saved to the view window (and updated as needed in model), and that saves a lot of fiddling with layers after placment! to recap that last example: one view window for Floor Plan, one view window for RCP, same file.
    S&D DB Sharing Forum
  1. ModelSpace V. PaperSpace
    By Christopher.cornell in forum VBA/COM Interop
    Last Post: 2007-07-12, 06:11 PM
  2. Replies: 9
    Last Post: 2007-01-10, 09:28 AM
  3. How can I tell if I am in Modelspace or Paperspace
    By bweir in forum VBA/COM Interop
    Last Post: 2006-11-16, 06:49 PM
  4. Can I WMFOUT from both Paperspace & Modelspace?
    By bmonk in forum AutoCAD General
    Last Post: 2006-08-01, 04:49 AM
  5. Object in Paperspace vs Modelspace
    By matt.worland in forum VBA/COM Interop
    Last Post: 2004-07-29, 02:38 PM
