Thread: Table trouble in Layout when use the mouse scroll wheel
    2006-02
    2
    Default Table trouble in Layout when use the mouse scroll wheel
    When I'm inserting a table in the layout, I can make it bigger by example scrollen my mouse. The problem is that this won't stop. So everytime I 'm scrolling or trying to move the layout paper up or down, only the table goes bigger/smaller or the table moves up/down. I 've tried clicking everywhere, but the table just keeps on moving.
    Aleks
    2001-03
    13,499
    Default Re: Table trouble in Layout when use the mouse scroll wheel
    Hi
    Can you please post an example drawing file that exhibits the behaviour you have described above.
    Have a good one, Mike
    2006-02
    2
    Normally you double click outside the Viewport or table and it is fine. Now Autocad was considering the Viewport on the entire page. So I couldn't double click outside the port. So now I double click on the gray part behind the page, if this is available.
    Thank you for replying.
    Aleks
    2001-03
    13,499
    Question Re: Table trouble in Layout when use the mouse scroll wheel
    Quote Originally Posted by das_redalb
    Hi
    If I am following correctly ( unlikely given my history ), have you looked at commands like...
    _.PSpace
    _.VpMax
    OR
    The "Model or Paper space" toggle button found on the AutoCAD status bar.
  1. Wheel Mouse = Scroll Bars
    By WileECoyote in forum AutoCAD General
    Last Post: 2009-10-09, 02:28 PM
  2. Mouse Scroll Wheel Zoom not working after computer change
    By graham_astle in forum ACA General
    Last Post: 2008-03-20, 04:28 PM
  3. Mouse wheel zoom switches to scroll
    By vagabondma in forum ACA General
    Last Post: 2007-12-07, 02:47 PM
  4. mouse scroll wheel
    By hirschnc in forum Revit Architecture - General
    Last Post: 2006-12-09, 06:45 PM
