Is there anyway to convert 3-D polylines to 2-D polylines? Any help will be greatly appreciated. Thanks!
Hi
Please note I have *moved* this thread from the AutoCAD Tips & Tricks forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Take a look at the links offered in this post ( RE: Filleting Polylines in 3D??? ).
Have a good one, Mike
hello
I have a lisp routine taked by Tony Hotchkiss and i will send you .
I hope that it help you.
[ Moderator Action = ON ] Copyright Material Removed. Rountine can be found here ( Convert 3D polylines to 2D polylines by Tony Hotchkiss ) [ Moderator Action = OFF ]
Last edited by Mike.Perry; 2006-02-13 at 08:43 PM. Reason: Copyright Material Removed.
try this:
Explode, flatten, pljoin
Explode the 3d poly line, start the flatten command, select "P" for previous, continue through the command using defaults, then when it is completed run PLJOIN and select "p" for previous, then continue through the command prompts using the defaults, when you are finished, you will have a regular polyline.
***note: you must have express tools installed to used flatten and pljoin
Another one of the 650+ tools in Toolpac.Originally Posted by kyleschmeusser
Toolpac | Convert | 3D to 2D Object
R.K. McSwain | CAD Panacea |
