Thread: Areas - Removing Columns from Floor Areas
    2002-06
    Default Areas - Removing Columns from Floor Areas
    Is it possible to remove columns from the net floor area?
    All AUGI, all the time Max Lloyd's Avatar
    2004-07
    London, England
    782
    Default Re: Areas - Removing Columns from Floor Areas
    go to the area plan view, select area boundary (under the area analysis tab), and simply sketch a boundary around the column (s) you want to remove.
    As long as this boundary forms an 'island' within the overall area boundary, it will be discounted from this calculation. If you then want to measure the area of the column, simply drop an area tag within the area of the column itself.
    Hope this helps.
    Max.
    2004-11
    115
    Another way.....
    1.Export to AutoCAD and import it.
    2.Under area analysis>Area Boundary>Pick lines then TAB key..
    You can save a lot of time...if you are working on a large area with lots of column & irregular shapes..
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    YOu can also do one column, add room bounding lines(or area lines depending on the application) then group them, then place your column group.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
  1. Can't tag areas???
    By jon.200969 in forum Revit Architecture - General
    Last Post: 2010-11-05, 04:02 PM
  2. Hatch Areas
    By JeffClark in forum AutoCAD General
    Last Post: 2010-09-03, 01:06 PM
  3. Changing Floor Areas of a Room
    By canzicek in forum Revit Architecture - General
    Last Post: 2007-03-02, 04:54 PM
  4. Room Areas
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2003-10-01, 07:31 AM
