Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Toolbars moving in AutoCAD 2006
    Active Member nickeshaffer's Avatar
    2006-01
    Spencer IA
    65
    Angry Toolbars moving in AutoCAD 2006
    I've never had this problem before until 2006... with my toolbars, I have them setup so my Draw toolbar is on the left, and the Modify is next to that (still on the left) and now for some odd reason, when i open up AutoCAD the Modify has moved below the Draw instead of next to it...
    any thought?
    2001-03
    13,499
    Default Re: Toolbars moving in AutoCAD 2006
    Hi
    Plug the following search criteria into the forum search facility ( hint - limit your search to the AutoCAD 2006 CUI Menus forum )...
    Key Word(s): *Toolbar* + *WorkSpace* + *Position*
    Have a good one, Mike
    2006-02
    84
    I have ditched 90% of my toolbars. I only use one customized toolbar, but I can take a shot at helping you... Have you tried locking the locations of your toolbars?
    Member Dhanjeet's Avatar
    2004-06
    Singapore
    7
    Hi,
    seems like the arrangement of toolbars you did is not saved while you close AutoCAD. Once you start AutoCAD again, they appear in same places. You need to use WSSETTINGS command and select AUTOMATICALLY SAVE WORKSPACE SETTINGS. Click OK and rearrange the toolbar. Once you restart AutoCAD, you could find the toolbars are on the same places where you moved last time. Hope this helps.
    cheers!
    dhanjeet sah
    www.dsviz.com
    2006-02
    84
    Quote Originally Posted by Dhanjeet
    Hi,
    cheers!
    dhanjeet sah
    www.dsviz.com
    Another legitimate point, but if you are not changing WorkSpaces, you shouldn't have that problem, I wouldn't think.
    2006-01
    Spencer IA
    65
    Quote Originally Posted by jm.pearson
    yeah, but didnt help any, it still moves down, but is locked there... if that makes sense
    2006-01
    Spencer IA
    65
    I do have my setting to automatically save my settings, and i dont change workspaces (im the CAD IT Guy... so we are actually in the process of switching over to 06 from 02 (HUGE Jump, and im lovin it!) so I have actually installed 06 three times on my computer to work out any future bugs with the rest of the installs we need to do... the first two installs i had no problems... the the third one (which i did identical to the second, just did it for documentation) this problem arrised.
    I hope that makes sense to you guys, cuz i just read it, and it's a little confusing (and im the one that wrote it!!!)
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    I have toolbars reset themselves every so often.
    Doesn't matter if I pay close attention to what I am doing in the CUI to prevent it......
    eventually I will just get lazy and BLAMMO! They go all over the place.
    Autodesk should do something about this
    2006-02
    84
    We, too, recently upgraded from 2002, but we went from 2002LT to full version 2006. That was a huge jump. But, it gave me a lot of things to look at, and a lot of configuring to do. The Engineers love that.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    We are using LDT 2006 and have experienced a similar problem but only with LDT toolbars.
    I don't have a solution to your problem but I do have a work around. If the user saves a workspace and then sets it to My Workspace, the preferred toolbar locations can be restored by clicking the My Workspace button on the Workspaces toolbar.
    Jeff Paulsen
  1. Toolbars moving around after Autocad Restart
    By INTELLIBIRD2 in forum AutoCAD CUI Menus
    Last Post: 2007-11-01, 03:16 PM
  2. migrate autocad menus / toolbars to adt 2006
    By tect75 in forum ACA General
    Last Post: 2007-06-20, 08:31 PM
  3. Transfer custom toolbars from AutoCAD 2006 to AutoCAD 2008
    By judekw in forum AutoCAD CUI Menus
    Last Post: 2007-06-19, 11:12 AM
  4. AutoCAD LT 2006 - Toolbars do not show up when placed via CUI
    By annperfect in forum AutoCAD LT - General
    Last Post: 2006-03-01, 10:58 PM
  5. Moving toolbars in ACAD Map 2006
    By cgarland.javanet in forum AutoCAD CUI Menus
    Last Post: 2005-11-16, 08:26 PM
