Map will read and write data from and ESRI ArcSDE data source on Oracle as well as SQL. The current release of Map works with Oracle. The current release of Map with the addition of a free service pack
http://usa.autodesk.com/adsk/servlet...3112&id=233443
5&linkID=2786655#section1 will work with Oracle SDE as well as SQL SDE.
THE QUESTION: The customer has Civil 3d 2006, is the same capability available in Civil3d as stated above for Map 3d (since Civil 3d is built on Map)??
Does anyone know what the answer maybe.
