I am new to 2006 and have run into a problem recently. I have found that when I insert a block or attach and xref ACAD scales the drawing up 12 times the original size even though I set the scale factor to 1.
After spending a hour yesterday trying to see what I did wrong, I saw a box called Block Unit in the insert DB that was set to 12. Even after I found out how to change this to 1 it still inserts the drawing 12x the original size.
What do I change or what am I doing wrong?
Thank you.
