Results 1 to 10 of 11
Thread: Unit Conversion; Block Scaling when Inserting or X-refing
    2003-12
    5
    Default Unit Conversion; Block Scaling when Inserting or X-refing
    I am new to 2006 and have run into a problem recently. I have found that when I insert a block or attach and xref ACAD scales the drawing up 12 times the original size even though I set the scale factor to 1.
    After spending a hour yesterday trying to see what I did wrong, I saw a box called Block Unit in the insert DB that was set to 12. Even after I found out how to change this to 1 it still inserts the drawing 12x the original size.
    What do I change or what am I doing wrong?
    Thank you.
    2006-02
    84
    Default Re: Unit Conversion; Block Scaling when Inserting or X-refing
    Quote Originally Posted by tdcrlh
    Thank you.
    I just had this problem. Go into the block, and check out the drawing UNITS. Make sure that the units in both the drawing that you are inserting to, and the drawing that you are inserting are the same (e.g. feet to feet, inches to inches). Sounds like one is using feet (probably the inserted), and the other (the working file) is in inches. Give that a try.
    2003-12
    5
    That seemed to do the trick.
    Thanks a million, it was about to give me a headache!
    What is the point of that feature anyway?
    2006-02
    84
    I think it just has to do with the line of work that different users use. Without getting way into it, it just attaches some sort of tag to the numbers. AutoCAD has always run "unitless", meaning that what we perceive as 3 inches, is defined by AutoCAD as 3 units. I don't know all the specifics, but I think they changed that, or at least masked it for 2006.
    2003-12
    5
    I see what you are saying. Its basically ACAD's attemp to convert what ever drawing you are inserting to the units that you are currently using. So instead inserting a file with no units or just accepting 12 inches as 12 feet. It tries to intellegently convert the drawing by saying the 12 inches is actually 1 ft.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Cool Re: Unit Conversion; Block Scaling when Inserting or X-refing
    I'd imagined this would have many other uses as well... I have plenty of drawings in my archives (that I use frequently) that wen't drawn 1:1, but, rather at a scale... and when reusing those old drawings, I'll choose to insert them so that they come in at the proper size.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    13,499
    Hi
    You might want to read up on...
    InsUnits
    InsUnitsDefSource
    InsUnitsDefTarget
    Have a good one, Mike
    Member Chris Matira's Avatar
    2005-08
    Philippines
    41
    Quote Originally Posted by Wanderer
    you could actually insert drawings with dimensions... when you try to explode the inserted block, dimensions will adjust accordingly to the scale it was inserted to...
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Does anyone know how Autocad deals with "Unitless"? It's got me a bit puzzled...
    If a block is created as "Unitless", and inserted into a drawing set to "Feet", the block is scaled by 12. Why? It makes sense when a block is defined as "Inches", but why does Autocad seem to assume "Unitless" = "Inches"?
    0,0,0 The Origin
    8,029
    Quote Originally Posted by richards.64879
    I think it assumes that unitless = inches in an imperial host drawing and millimetres in a metric drawing. They probably decided that those were the most common usage.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. Unit Conversion
    By William.Gares in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-11, 05:49 PM
  2. unit conversion
    By dbutler.144607 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-10-26, 05:41 PM
  3. Replies: 5
    Last Post: 2007-06-12, 06:03 PM
  4. Language / unit conversion
    By troy.barnette in forum AutoCAD Customization
    Last Post: 2006-12-17, 02:58 PM
  5. Inventor Unit Format Conversion
    By bweir in forum VBA/COM Interop
    Last Post: 2006-03-03, 09:01 PM
