Results 1 to 7 of 7
Thread: How can i make a railing of this type?
    2005-11
    42
    Default How can i make a railing of this type?
    I have no idea where to start on this one. I hope it's even possible. The elevation and detail I posted should be enough to give you the idea of what I'm looking for. Thanks alot for any direction.
    2003-09
    1,907
    Default Re: How can i make a railing of this type?
    Aaron. Is this for a 3d presentation, or are you doing a 2d presentation /WD?
    Use a hatch to define the mesh on a railing panel if not 3d, and draw your section 2d. You could do this, but it would take some time. Kinda hard to read your posted images in section though.
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    697
    How would you model this type of rail if you had to?
    Would be nice if we had a 3D model hatch pattern capability.
    Could be used for chain link fence, expanded metal, welded wire, bird screen, etc.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    You do have that ability, create a material called mesh, set it to have a crosshatch pattern(surface) set the transparency in the shaded box of the material to 100.
    Note: I know it will be transparent in 3d, not sure about elevation.
    Scott D. Brown, AIA
    BECK
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Not in elevation, I think.
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    I had those issues with a screen porch made with curtain panels. In elevations I turned the curtain panel visibility off and replaced them with transparent filled regions. I don't see how you can turn the railing panel visibility off though. Perhaps the railings could be built with the curtain wall tool. Also in Isometric plotting I had to use raster to maintain the transperency of the panels.
    2005-11
    42
    i only need this to work in the renderings...thats it. Thanks for the suggestions, I think im going to try and model everything using extrusions and sweeps though. I'll let you guys see how it turns out...thanks.
  1. 2014: Can't make type
    By jochem25712364 in forum Revit Architecture - General
    Last Post: 2014-04-10, 09:52 PM
  2. Generic railing tool to make other types of objects.
    Last Post: 2013-05-05, 09:20 PM
  3. 2012: Railing schedule: no filter by type?!
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2012-05-31, 07:47 PM
  4. Can't make railing?
    Last Post: 2007-10-12, 12:10 PM
  5. Error msg: Can't make type
    By kimheaver in forum Revit Architecture - General
    Last Post: 2004-11-01, 06:15 AM
