Results 1 to 6 of 6
Thread: Automatically show the word "EQUAL" instead of the actual dimension
    2002-01
    Birmingham, Alabama, U.S.A
    Question Automatically show the word "EQUAL" instead of the actual dimension
    I want to set up a dim. style that will automatically show the word "EQUAL" instead of the actual dimension. Can that be done and how do I do it?
    Using ACAD 2000i
    2001-03
    13,499
    Default Re: Automatically show the word "EQUAL" instead of the actual dimension
    Hi
    Please note I have *moved* this thread from the CAD Standards forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    2001-03
    13,499
    Hi
    I am not so sure you can ( but then again I am wrong all time )...
    Take a look at the following threads, for some ideas...
    Add text "REF" to dimensions
    Add tolerances to dimensions
    Have a good one, Mike
    100 Club avdesign's Avatar
    2005-08
    STL Metro
    173
    I've always done the good ol' text override to get equal in. One trick I've done is copy a generic dim into my handy Text template drawing text override the dim and then copy it in to a drawing when I needed Equal and then move the grips to fit the area. It's not nice, or automatic but it works.
    Houston
    7,519
    Quote Originally Posted by pallen
    Using ACAD 2000i
    AFAIK - there is no way to force a dimstyle to not include the measurement itself.
    You could use something like the code below to override the text (adjust the command name as required)
    (command "._dimlinear")
    (while (eq 1 (logand (getvar "cmdactive")))
      (command pause)
    (command "._dimedit" "_N" "EQUAL" (entlast) "")
    2005-08
    STL Metro
    173
    Quote Originally Posted by rkmcswain
      (command pause)
    That works too.......
    This might be a good ACAD wish list item 2¢
  1. Replies: 10
    Last Post: 2010-03-11, 11:49 AM
  2. Dimension with the word "ALIGN" only
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-02-26, 04:36 PM
  3. Dimension with the word "clear" underneath
    Last Post: 2010-02-25, 10:50 PM
  4. How to show "last printed" or "path" text in layout
    By cstone in forum AutoCAD General
    Last Post: 2008-11-28, 11:05 PM
  5. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
