anyone got a lisp routine that makes a text align parallel to a line?
i'm having a lot of time spent rotating text to make it parallel to a line.. this would really help...
thanks...
thanks...
Here is a simple code in the fly for you to start with
no errorhandler, no user trapping security
just rotate selected text equal to one selected line.
: ) Happy Computing !Code:(defun c:AlignText (/ VlaObjLine LinAngle VlaObjText ) (vl-load-com ) (setq VlaObjLine (vlax-ename->vla-object (car (entsel "Select the line : " ))) ) (setq LinAngle (vla-get-Angle VlaObjLine ) ) (while (setq VlaObjText (vlax-ename->vla-object (car (entsel "Select the text : " )))) (vla-put-Rotation VlaObjText LinAngle ) (vlax-release-object VlaObjText ) ) (vlax-release-object VlaObjLine ) (princ) )
kennet
If you have Express then it has a command that does that also, it's called torient, but it asks for two points to get the rotation angle instead of a line.
Hi Thanks for the Code, is any one having a lisp that can align the text parallel to polyline with certain given distance means offsets from the source polyline.
Thanks in advance.
