Thread: Terramodel Vs Civil 3D
    100 Club Kris.Keller's Avatar
    Rigby, Idaho
    106
    Default Terramodel Vs Civil 3D
    We currently use Terramodel in our office and we are looking at maybe using Civil 3D. For those who have used both please share your pro and cons for each.
    Thank you,
    Kris
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    Default Re: Terramodel Vs Civil 3D
    Civil 3D is a completely different animal if you are used to working with terramodel. You will need to get accustomed to applying 'Styles' to objects and creating them. But as far as production, once your team gets the concepts down, you should see some improvements in production. 3D takes a little getting used to, but it works as fast, if not faster than Terramodel.
    2005-03
    50
    I didn't have the luxury of using Terra Model. I have learned that there will always be pros and cons to whatevery you choose. The main differentiator between Civil 3D and the other civil apps I have used or understand thoroughly, is that the building blocks of Civil 3D are intelligent objectswhere as the building blocks of other applications are "primitive or unintelligent" objects. With the intelligent object, comes an abundance of dynamics that is unprecendented in what I have seen and quite amazing!
  1. 2014: Civil 3D 'shared reference point tool' and 'Integration with Civil 3D' revit extension problem?
    By alex.bell.252970 in forum Revit Structure - United Kingdom
    Last Post: 2013-11-26, 02:15 PM
  2. Replies: 0
    Last Post: 2013-04-17, 04:22 AM
  3. Moving from Trimble Terramodel to Civil 3d
    By garrettwynne in forum AutoCAD Civil 3D - General
    Last Post: 2012-04-25, 04:57 PM
  4. Se puede instalar civil 3D 2009 y civil 3D 2010 en un mismo Windows
    By wuari in forum AutoCAD Civil 3D - General
    Last Post: 2009-11-22, 03:27 AM
  5. Civil 3D 2007 - How does file structure and standards relate to Civil 3D
    By eleonard in forum AutoCAD Civil 3D - General
    Last Post: 2007-01-22, 06:05 AM
