Results 1 to 6 of 6
Thread: Corrupted Hatch pattern file - "Error in reading the pattern file"
    I could stop if I wanted to Haden's Avatar
    2004-05
    St. Louis, Missouri
    292
    Angry Corrupted Hatch pattern file - "Error in reading the pattern file"
    I have been fooling with pulling hatch patterns from old .pat files, and in the course of trying to extract one of my favorite hatch patterns (wood endgrain), I seem to have somehow corrupted my installation of AutoCAD with respect to the .pat file it reads from. Part of my problem is that in AutoCAD 2006, I don't know how to tell what specific acad.pat file is being used by AutoCAD.
    My problem now is that any time I issue the Hatch command, I get an error that says:
    then the hatch pattern palette windows are all blank except the "Other Predefined," which contains only the one endgrain pattern, which is apparently the offending pattern. No matter what I try now, I can't seem to reset the patterns back to the acad.pat which I can find in what I suppose is the correct directory, which is a directory I have set in my support file search paths.
    No matter how many times I try reopening and creating a drawing from scratch, this problem will not seem to go away.
    Thank you very much in advance for any help. . .
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Corrupted Hatch pattern file - "Error in reading the pattern file"
    In your efforts to extract the old patterns, how did you extract them? Did you place them all in the same file? Did you place each pattern in its own pat file?
    I usually do the latter when making custom patterns available for AutoCAD.
    13,656
    Hi
    For starters work through all the information available in the following thread...
    Load custom hatch pattern
    Have a good one, Mike
    I could stop if I wanted to hugh.69031's Avatar
    2016-01
    Melbourne, Australia
    360
    If you are running AutoCAD (not Autocad LT) you can ask Lisp. At the command prompt type the following line including the parantheses and quote characters:
    (findfile "acad.pat")
    Then double check with:
    (findfile "acadiso.pat")
    to show where the pattern definition files' directory is located.
    You can also search for other files, so if you are keep custom pattern files away from the standard files you can find them in the same way, for instance
    (findfile "MYGRAVEL.pat")
    may turn up a copy of that file in a different directory from where you expected to find it.
    hth
    Hugh Adamson
    Cadro Pty Ltd
    www.cadro.com.au/hatchkit/
    2004-05
    St. Louis, Missouri
    292
    My individual .pat file was named AS-WOOD-ENDGRAIN.PAT, but my pattern within the file was named AS-WD-ENDGRAIN. The old mis-matched name!
    I had to fix the file name, close AutoCAD, and when I reopened, everything was peachy. Thanks for the help!
    13,656
    Thumbs up Re: Corrupted Hatch pattern file - "Error in reading the pattern file"
    Quote Originally Posted by hadens
    Hi Haden
    Thanks for posting back the solution that worked for your situation. I am sure others will benefit from such information in the future.
    Mike
  1. Revit "File Not Saved" error when saving a central file on a server.
    By jakevaj341980 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2018-08-09, 08:13 PM
  2. 2014: Need Hatch pattern for "Void Form"!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2015-02-04, 12:00 PM
  3. Hatch pattern - error in reading pattern file
    By bbapties in forum AutoCAD Customization
    Last Post: 2011-04-01, 11:40 PM
  4. Error in reading the pattern file
    By jfoss3 in forum AutoCAD General
    Last Post: 2008-12-02, 02:21 PM
  5. Hatch pattern becomes "scrambled"
    By gpbrady in forum AutoCAD General
    Last Post: 2006-01-20, 08:37 PM
