Originally Posted by
l-schultz
I'm trying to format a document using MText that has text separated by tabs. I want the separation space to consist of dots to make it easier to connect the two pieces of information.
I can do this in Word 2007 by going to Paragraph, Tabs and setting 'Leader' tab stop positions.
I'm trying to do the same in MText with no luck.
I entered MText, then went back to format it by right clicking on Paragraph, then using the 'Tabs' Section of the Paragraph menu to create tabs, and specifying the 'Period' Decimal Style. I thought this was the same thing as Leaders, but have learned that the decimal tabs serve only to align the decimal points on different numbers that are on different lines of text.
Here's what I want to do in a buidng direcory:
"Administation Offices..............................C Building"
(I put the dots in here manually, I want them to be automatic via tabbing instead)
Is there a "Leader" tab stop function in MText?
