Thread: Columns not being painted
    2003-11
    South Africa
    14
    Default Columns not being painted
    I tried everything, but did not manage to understand why columns n. 01 and 03 do not appear painted as remaining columns. Could anyone please tell me where is the mistake?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Columns not being painted
    It seems to be a wall join issue. On the offending columns, use the wall join tool to toggle thru different join options, and you should find one that'll make them show.
    Might want to send this to the factory also, as a possible bug...
    100 Club ejc's Avatar
    2001-04
    125
    Work around:
    I erased column 1 and replaced it with a copy of column 2. The new column remained colored ?!?!?
    Trouble shooting:
    Match command indicates Revit considers both columns to be identical.
    Changed all parameters to of col 1 to match col 2 no change.
    Moved / Copied col1 to different walls, no change. (except that thinner walls allow the col1 to show green overhang)
    This would leave me to believe that something freaky weird happened with these columns. Quick-n-Nasty correction is to erase and copy.
    Also, try and think of anything weird that might have happened when creating the offending columns!
    Later,
    ejc
  1. 2013: painted CMU - I need white
    By CADMama in forum Revit - Rendering
    Last Post: 2013-01-23, 09:05 PM
  2. selecting painted on materials
    By vanderloo5 in forum Revit Architecture - General
    Last Post: 2008-12-29, 03:43 PM
  3. selecting painted on materials
    Last Post: 2008-12-28, 10:30 PM
  4. What Material Has that been painted with
    By Davied2 in forum Revit Architecture - General
    Last Post: 2005-05-18, 02:23 PM
  5. painted walls
    By TeamRPM in forum Revit Architecture - Families
    Last Post: 2004-03-23, 05:03 PM
