I would like to be able to trim intersecting roofs so the inside faces make a clean join. (see attached). I know I could use a void to clean it up, but that would mean I would have to use three different steps: 1) cut an opening in the main roof 2) cut the secondary roof to the opening and 3) create a void to trim the excess. There should be a command that trims roofs like walls.
