Thread: Witness Line gap control
    2003-10
    Belgrade
    181
    Default Witness Line gap control
    How does it work? Suddenly I have to manually pull every witness line to the dimensioned object and I don't see any unusual setting in dimension controls.
    First placed, witness line offset is 19" as seen on V1 and V2.
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Witness Line gap control
    tarch
    In attachment a quick setup to a situation a think which is similar to yours. (Upper row of doors)
    As you can see the Dim Line references towards the door swings Symbolic Line ruled by a nested Ref Line in the Door family. (Row of doors below)
    So ... Select the Dim. line > Edit Witness Line and have a look a the red lines that show up as the Dim. Line references.
    Edit/adition : check the concerning Rfa's Elements Properties > Other > Is Reference, Not a Reference etc.
    2003-10
    Belgrade
    181
    Thanks Eddy
  1. Witness Line Disappeared
    By mhicks.205618 in forum Revit MEP - General
    Last Post: 2009-08-13, 04:04 AM
  2. Witness line dimension out of view!
    By blumarble in forum Revit Architecture - General
    Last Post: 2006-05-09, 07:53 PM
  3. Temp dim witness line snaps
    By tim.olson6 in forum Revit Architecture - General
    Last Post: 2005-02-12, 06:44 PM
