Hi VBOYAJI,
Basically, positive numbers are pen down, negative numbers are pen up, and 0 is a dot. You've probably already figured out the text portion, but "ST" is what is displayed, STANDARD is the style to use, S is the scale, R is rotation, X is the offset along the line and Y is the offset in Y.
Is your intent really to start with a dot, as your description defined in the definition suggests? If so, try this:
*CONDUIT_IN_THE_STREET,Conduit in the Street .-- ST --.-- ST --.-- ST --.
A,0,-.2,.3,-.2,["ST",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2,.3,-.2
This works, but looks kind of funny to me ~shrug~, but at least it doesn't have symmetry issues. It does, however have issues with the spacing between the end dots and first dash.
If your intent is to start with a dash, per your description in your post, this is as close as I could get with 2 dashes and one dot:
*CONDUIT_IN_THE_STREET2,Conduit in the Street --ST--.--ST--.--ST--
A,.3,-.2,0,-.2,.3,-.2,["ST",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2
It has symmetry issues between the ends, as Autocad ignores all but the first dash for making sure there is a dash at each end (that's what the A is for in the definition, and it's required). I'm not sure if this matters to you or not.
But, if three dashes and two dots between ST are ok, try this
*CONDUIT_IN_THE_STREET3,Conduit in the Street --ST--.--.--ST--.--.--ST--
A,.3,-.2,0,-.2,.3,-.2,["ST",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2,.3,-.2,0,-.2
IMHO this looks better, but the dashes at the ends can get pretty long. At least it has symmetry.
I hope this helps,
