Thread: Unresolved References.
    2004-03
    15
    Default Unresolved References.
    Dear Friends,
    I created a drawing having two views & part lists of two different assemblies say "Asm1" & "Asm2". Due to some reason I don't need one of the view of assembly "Asm1". So I delete the view & part list of assembly "Asm1".I also delete the the assembly file because I want to create a new assembly with the same name.
    Next time when I was opening the drawing file, It is giving me an error message regarding unresolved references of assembly "asm1" '. If I skipped the references the drawing file is opening but every time while opening it is giving me the message. If I give the path of new assembly with the same name, it is saying that the references is not the same with previous one.
    Can anybody tell me, what can I do so that I can open the drawing without any error message?
    Regards,
    Amey
    I could stop if I wanted to Ron Oldenbeuving's Avatar
    2004-06
    Lewiston, South Australia
    291
    Default Re: Unresolved References.
    Did you save and close the idw prior to deleting the assembly file? This would be the correct order to use to avoid this error in the first place. HTH, Ron
    2004-03
    15
    Dear Ron Oldenbeuving,
    Thank you for your prompt response. The solution given by you is not working in my case.
    Any suggestions?
    Regards,
    Amey
  1. File keeps throwing up Unresolved References error
    Last Post: 2010-09-02, 05:51 PM
  2. Unresolved Xref
    By asmckee in forum AutoCAD General
    Last Post: 2010-03-19, 06:52 AM
  3. Unresolved Xrefs
    By christopheram85 in forum AutoCAD General
    Last Post: 2008-05-21, 02:57 PM
  4. xref unresolved
    By crbickel in forum ACA General
    Last Post: 2007-03-28, 12:12 AM
  5. Unresolved Xref
    By Shizzjr in forum AutoCAD General
    Last Post: 2005-12-19, 05:17 PM
