Thread: Construction line projection
    ACAD Wish List Administration
    2005-06
    1,920
    Default Construction line projection
    Summary: The ability to set a construction line projected from an existing object, or set at an absolute angle
    Description: A construction line that can be projected from an existing object or set to absolute angle.
    (a bit like the xline but one pick)
    How Used: to project lines from plans to section/elevations
    Feature Affinity: Drawing Tools 2D
    Submitted By: Simon Ward on February 9, 2006
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Default Re: Construction line projection
    Quote Originally Posted by acadwishlist
    Have you tried the other options in the xline command? You can set an absolute angle or an offset from an object. Is that what you are talking about?
    2011-08
    4,581
    Exclamation Re: Construction line projection
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. Assigning Line Weight Projection to Material
    By kalimazoop in forum Revit MEP - General
    Last Post: 2010-01-07, 05:11 PM
  2. Projection/Surface Line Color Override negates Line Weight
    By nosten in forum Revit Architecture - General
    Last Post: 2008-09-30, 07:57 PM
  3. Reference Line Projection
    Last Post: 2006-05-07, 03:36 AM
  4. Projection Plane Line styles
    By Jshaver in forum Revit Structure - General
    Last Post: 2005-11-15, 09:20 PM
  5. Projection of line weight at openings.
    By JTF in forum Revit Architecture - Wish List
    Last Post: 2005-04-29, 12:06 PM
