Say I have a 3 storey office block (see attached image) all the openings in the walls for the curtain walling can be formed using the edit elevation profile or the split tool to make them into separate walls....
Something I have been doing recently which REALLY speeds things up compared to using the edit elevation profiles oe the split tool is to create an inplace family, draw voids, then cut the geometry out... it is so simple and so fast. BUT there are 2 major bugs.
The first one - I cannot snap to "ends" of the walls at the openings??? very annoying.
The second problem is as soon as I remove any of the walls that are haveing their geometry cut - Revit stops cutting geometry at all with the family and I have to go round doing it all again.
Aside from fixing these bugs, it would be very cool if I could make revit automatically split all the walls into separate segments based on this cut geomtry - or to edit the elevatio profile to match it, I tihnk it is something like massing I want it doing, though I dont use the massing tools so maybe it already can?
