Results 1 to 10 of 19
Thread: insert .bmp
    100 Club timothyjturner's Avatar
    2005-09
    Columbus, OH
    101
    I am working on a lisp where the user can choose to insert their digital signature into a drawing. We have our digital signatures in .bmp format in separate locations on our computers. I am looking for a line of code that will let the user browse to their .bmp file and insert it. I tried using (command "_imageattach" ...) but i'm having no luck. When the user browses for the .bmp it prompts them for all this other data that I already have preset in my program... i.e. insertion pt, size, rot angle.... I just need something to help the user browse, everythign else is set.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: insert .bmp
    Look into the getfiled function.
    2005-09
    Columbus, OH
    101
    The getfileid function seems helpful, but how do I insert a .bmp without using the command _imageattach? Is there a better method that will not bring up the extra dialog box asking for the details I mentioned above?
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by timothyjturner
    Have you tried using the command line version of the image command? You would need to supply the filename from the getfiled function.
    There is probably some visual lispcode that would do this without even using the command line.
    2005-09
    Columbus, OH
    101
    I messed around with this a little bit and I seem to have the same type of problem... once I execute the command, it pretty much shuts down my program... I insert and it asks me all the questions again via the command line...
    Somehow I need to...
    Do previous lisp commands ---> Insert Image ---> Modify image properties via lisp ---> finish lisp program
    With no interuptions
    2005-08
    1,043
    Do something like
    (initdia 0)
    (command "_.image")
    This will supress the dialog box. Run it once so that you know how to answer all the prompts.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Wouldn't "-image" also work?
    2005-08
    1,043
    Quote Originally Posted by timcreary
    I tried it before I posted. Didn't work.
    Command: (command "-image")
    Unknown command "-IMAGE". Press F1 for help.
    nil
    Lost
    1,473
    That's strange; it works for me. What version are you running?
    2005-09
    Columbus, OH
    101
    I'm still having trouble. Maybe I'm just not understanding how to answer the prompts from the routine and continue on with the program? Even if i answer the prompts manually...it does not complete the rest of the program. Also with this method it did not even bring up a dialog box for me select the bmp file....let me post my entire code, maybe this will help...
    (defun C:reviewstamp ()
    	(setq os (getvar "osmode"))
    	(setq cl (getvar "clayer"))
    	(setvar "osmode" 0)
    	(setq test 1)
    		(setq blockinsert (getstring "Is this block Approved? approved as Noted? to be Revised? <A/N/R>:"))
    		(cond
    		((or (= blockinsert "A") (= blockinsert "a"))
    			(setq insertstring "\\\\Fileman\\MAC\\Engineering\\Drawings\\AutoCAD Designers\\acad2004\\program files\\acadlisp\\reviewstamp\\approved.dwg")
    		((or (= blockinsert "N") (= blockinsert "n"))
    			(setq insertstring "\\\\Fileman\\MAC\\Engineering\\Drawings\\AutoCAD Designers\\acad2004\\program files\\acadlisp\\reviewstamp\\approvedasnoted.dwg")
    		((or (= blockinsert "R") (= blockinsert "r"))
    			(setq insertstring "\\\\Fileman\\MAC\\Engineering\\Drawings\\AutoCAD Designers\\acad2004\\program files\\acadlisp\\reviewstamp\\revise.dwg")
    	(setq blkscale (getvar "DIMSCALE"))
    	(setq pt (getpoint "Select insertion point:"))
    	(command "insert" insertstring pt blkscale "" 0)
    	(command "explode" "L" "")
    	(setq sigdatepty (- (nth 1 pt) (* 0.9375 (getvar "DIMSCALE"))))
    	(setq sigx (- (nth 0 pt) (* 0.5625 (getvar "DIMSCALE"))))
    	(setq datex (+ (nth 0 pt) (* 1.5 (getvar "DIMSCALE"))))
    	(setq bmpptx (- (nth 0 pt) (* 1.5 (getvar "DIMSCALE"))))
    	(setq sigpt (list sigx sigdatepty 0))
    	(setq datept (list datex sigdatepty 0))
    	(setq bmppt (list bmpptx sigdatepty 0))
    	(setq signature (getstring "\nWould you like to Type your signature or insert digital signature .bmp from a File? <T/F>:"))
    		(cond
    			((or (= signature "T") (= signature "t"))
    				(setq printsig (getstring T "Type your signature:"))
    				(setq txtsize (* 0.1875 (getvar "DIMSCALE")))
    				(command "clayer" "text")
    				(command "Text" "j" "bc" sigpt txtsize "0" printsig "")
    			((or (= signature "F") (= signature "f"))
    				(initdia 0)
    				(command "_.image" "a" bmppt (getvar "DIMSCALE") 0)
    	(setq date (rtos (getvar "CDATE") 2 8))
    	(setq datetxt (strcat (substr date 5 2) "/" (substr date 7 2) "/" (substr date 1 4)))
    	(setq txtsize (* 0.125 (getvar "DIMSCALE")))
    	(command "Text" "j" "bc" datept txtsize "0" datetxt "")
    	(command "clayer" cl)
    	(setvar "osmode" os)
  1. Insert DWG in DWG via vb.Net
    By drewj in forum Dot Net API
    Last Post: 2012-12-03, 05:01 PM
  2. Map Insert VS FDO
    By jenniferchavez in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-01-12, 11:08 PM
  3. Insert Sheet List - Won't insert
    By chris.klinert in forum ACA General
    Last Post: 2008-12-18, 03:45 PM
  4. Insert OLE
    By a.r.t.studio in forum AutoCAD General
    Last Post: 2005-07-07, 10:59 PM
  5. Name that insert
    By Maverick91 in forum AutoCAD General
    Last Post: 2005-06-14, 01:25 PM
