Hai Friends,
Can we create our own Shortcut Keys for particular commands. If so where can we create, save and load them in the menu.Hope u can give me an answer.
thanks in advance
BASHA
Hai Friends,
thanks in advance
BASHA
Hi
Are you referring to...
Shortcut command alias keys ie Acad.pgp ( ID: TS29743 - Create or modify command aliases / ID: TS19364 - Using the Command Alias Editor to create, modify or remove command aliases ).
OR
Shortcut key combinations ie Ctrl + Key or Shift + Key or Ctrl +Shift + Key ( ID: TS1053095 - Keys that can be used for CUI keyboard shortcuts ).
Have a good one, Mike
From Robert Bell's AU2005 What to do With the New CUI class :
"You need to use drag-and-drop to add a new shortcut key. If you right-click on the Keyboard Shortcuts or Shortcut Keys node and select New, shortcut keys are not an option. However, to create a new shortcut key all you need to do is drag-and-drop a command on to the Shortcut Keys node. You then edit the Key(s) property to assign a keystroke combination to the command."
If you want to see the whole handout you can download it from AU Online. It is class number CP11-1. If you attended AU or are on subscription access is free.
http://auonline.mentorware.net/servl...2&file=auol_lp
