Thread: What is more critical when loading large Image files? RAM or Graphics Card
    2003-01
    64
    Default What is more critical when loading large Image files? RAM or Graphics Card
    For those experts out there in memory and systems in general - which is more critical for loading large raster images into a drawing - the amount of RAM your system has or the amount of RAM on your video card?
    For example - i have a drawing with 6 TIFF images that are each about 330MB. I could load this drawing with no problem in Acad (with Raster Design loaded), but have since changed to Civil 3D (with Raster Design) and can longer load the drawing without encountering a fatal "Out of Memory" error. I was running 1 GB of system memory with a 128 MB video card and have since upgraded to 4 GB or RAM with the same 128MB video card. It doesn't seem to make any difference - the additional RAM still won't load the drawing. Any ideas?
    Thanks
    2003-08
    13
    Wink Re: What is more critical when loading large Image files? RAM or Graphics Card
    ARD uses a hard disk swap file, not RAM. This is why in options there is a 50meg limit on RAM. Set the "Temporary File Location" in ARD Options to a location with many GIG of space. The temp files will be quite large. Using a second harddrive or very fast hard drives will also help. Also I convert all .tiff files to .jpg. this seems to help as well.
    I could stop if I wanted to de-co1's Avatar
    2005-07
    Jhb - ZA
    260
    Default Re: What is more critical when loading large Image files? RAM or Graphics Card
    In addition to what jgtb says, your graphics card will only really come into play when regenerating on screen. Zooming and panning around will benefit from a higher spec graphics card, but won't assist you with your 'out of memory' problem.
    David
    "Artists to my mind are the real architects of change, and not the political legislators who implement change after the fact."
    William S Burroughs
  1. Civil3D 2011 graphics card for large topo models
    By kreed.210753 in forum Hardware
    Last Post: 2011-08-11, 02:00 PM
  2. Graphics card ?
    By Statler in forum Hardware
    Last Post: 2008-09-22, 01:44 PM
  3. more ram vs better graphics card
    By rickfennell.153918 in forum Hardware
    Last Post: 2007-11-28, 10:11 PM
  4. graphics card
    By Max Lloyd in forum Revit - Hardware & Operating Systems
    Last Post: 2005-05-11, 08:49 AM
  5. Graphics Card
    By cgrover in forum Revit - Hardware & Operating Systems
    Last Post: 2003-10-07, 11:39 PM
