Thread: Profiles On Arched Walls
    2003-03
    Reno, Nv.
    277
    Default Profiles On Arched Walls
    I have a wall where I have edited the wall profile to achieve an arch. However, I cannot seem to attach a profile to the top. The profile is supposed to match the profile on the other walls. I'm not sure what I doing wrong.
    Thanks.
    I could stop if I wanted to bpayne's Avatar
    2016-01
    Apex, NC
    211
    Default Re: Profiles On Arched Walls
    Use an in-place family sweep to get your desired result.
    Also, you will probably need a void at either end to "cut off" the sweep
    2003-03
    Reno, Nv.
    277
    Thank you. I got brain lock on this and was trying to create a family, without doing it in-place and I was making things difficult.
    Thanks.
  1. how do i join walls with modified profiles
    By timsea81 in forum Revit Architecture - General
    Last Post: 2009-12-07, 02:38 AM
  2. Joining different thickness wall in arched profiles
    By 2bloom in forum Revit Architecture - General
    Last Post: 2009-04-14, 01:27 PM
  3. Arched Curtain Walls?
    By gforsburg in forum ACA General
    Last Post: 2005-08-18, 03:12 PM
  4. vertically compound walls - visibility for profiles
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2004-10-15, 12:42 AM
  5. defining walls with the family editor - as profiles
    By J-G in forum Revit Architecture - Wish List
    Last Post: 2004-01-10, 11:07 PM
