Thread: Modify xref path
    Houston
    7,519
    Default Modify xref path
    Yes, I know it's a free program
    Yes, I know this isn't the wishlist
    ...but, having the ability to set xref paths would be nice.
    (Yes, I know it won't save it.)
    Case in point: We have a couple of non-CAD users browsing through some archived drawings (using DWG TrueView) - all they know to do is double-click a DWG file.
    The xref paths saved in these drawings don't even exist any more. So the drawing opens and 3/4 of it is missing due to unloaded xrefs. I suppose they could figure out the path and name from the text that prints the name of the missing xref in the drawing, but there is still no way to "reload" the missing xrefs - short of finding them all and putting them in the same directory as the main drawing -or- adding their path to the support file search path. --- and then closing and reopening the drawing. Both more difficult.
    Ok, stepping down from the soapbox....
    2001-03
    13,499
    Question Re: Modify xref path
    Hi R.K. McSwain
    Is the above a "soapbox" ( your words ) moment OR is it a DWG Trueview Wish List item request ie Should this thread be moved to here ( DWG Trueview Wish List forum ).
    Thanks, Mike
    Forum Moderator
    Houston
    7,519
    Default Re: Modify xref path
    Quote Originally Posted by Mike.Perry
    Should this thread be moved to here DWG Trueview Wish List forum
    Either way is fine with me. I didn't realize they were taking wishes for free products...
    2001-03
    13,499
    Thumbs up Re: Modify xref path
    Quote Originally Posted by rkmcswain
    Hi R.K. McSwain
    Done.
    Thread moved from the DWG Trueview Wish List forum to this one.
    Thanks, Mike
    Forum Moderator
  1. Xref path - Saved path vs. Found at
    By jsowinski in forum AutoLISP
    Last Post: 2010-08-27, 06:11 AM
  2. Sweeps, Modify Picked Path
    By cadman6735 in forum Revit Architecture - General
    Last Post: 2010-03-25, 05:13 PM
  3. Change Xref from Full Path to Relative Path
    By ccowgill in forum AutoLISP
    Last Post: 2009-05-27, 11:54 AM
  4. XREF MODIFY
    By ablair.69905 in forum AutoCAD General
    Last Post: 2004-07-21, 07:27 AM
