Hello all,
I have a client who can't seem to get any command that requires his tracking lines to work.
Any suggestions?
Thank you!
Hello all,
Any suggestions?
Thank you!
that sometimes happens to me when my 'polar' button is also toggled off.Originally Posted by melanie.santer
S&D DB Sharing Forum
Polar is on, all the polar settings are on in the Options, we have done a complete uninstall and reinstall (deleting registry items as well) we have even ran a repair.
Hi
Maybe...
ID: TS33623 - Polar tracking stops functioning when an object snap override is used
Does TT ( Temporary Object Snap Tracking ) and TK ( Tracking / Track ) work as a Command Modifier for this person ?
Have a good one, Mike
Hello Mike,
This doesn't seem to be the issue either. My client can't even use the extension OSNAP. Any command that requires extension/tracking lines does not work.
HiOriginally Posted by melanie.santer
Just so I am clear in my own mind...
I take it, TT ( Temporary Object Snap Tracking ) and TK ( Tracking / Track ) does not work as a Command Modifier for this person ?
What about typing OSnaps modes at the Command Line, do they work or not ?
OSNAP's work, but the extension OSNAP does NOT work. Anything command that has to do with extension lines does not work. Does that make sense?
Nope! but you are talking to me, remember...
Have they got "Shift to Acquire" ( Alignment Point Acquisition ) toggled "ON" ? Found on the "Drafting" tab of the Options dialog box.
I am having the same problem.
I am using AutoCAD Architecture 2013, and my running osnaps keep overriding my "from" or "tracking" osnap. How do I fix this?
the only thing I have found to fix the problem is to select everything and make sure the Z depth is set to zero.
Even though the properties for the objects will all say it is zero, it is not.
