Page 1 of 56 123451151 ... LastLast
Results 1 to 10 of 552
Thread: Revit Running on Intel Mac
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    Default Revit Running on Intel Mac
    Corner 1: IBM T43p w/ 1 gig ram.
    Corner 2: MacBook Pro Dual Core w/ 1 gig ram.
    See attached.
    http://onmac.net/
    Install was moderately difficult. Read the Wiki at onmac.net.
    You have to reboot to switch between OSs. Graphics do seem a bit sluggish (no graphics driver is yet available). Open times, view creation times, save times all see fine. Its more a matter of view rotation that shutters.
    Oh yeah - need a two-button mouse...
    Hey Guy! Getting closer!
    -Phil
    2003-05
    Charlotte, NC
    398
    Default Re: Revit Running on Intel Mac
    Test 1: Execute Journal File of Revit Hotel project (49.2 megs). Worksets enabled. Open, render, save and close.
    Zip of MP4 file attached. That's right. Quicktime required.
    -Phil
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Hmmm... interest is peaked... but I'm not following you... a bit too cryptic... care to elaborate?
    (and I'm not seeing any quicktime attachment here...)
    2003-05
    Charlotte, NC
    398
    Ok - a bit more detail (and hopefully the file). Basically I started up the Revit Hotel project (created in 5.1 - but upgraded to 8.1). Then I selected a view, rendered it, exported the view, saved the project file and closed Revit.
    The resulting Journal file and Revit project was copied to the MacBook. The Journal file was then executed on both systems simultaneously. From open to close, the MacBook finished in 3:50 and the IBM kept going till 5.20.
    I admit...completely unscientific.
    Worksets seem fine. Keyboard Shortcuts work. Rendering alone is faster by a third.
    A bit ironic considering its still a few days shy of April 1st. But then again, I believe that was Mr. Jezyk's handiwork.
    -Phil
    2004-10
    usa
    1,591
    Sweet! Thanks for sharing!
    I assume you accomplished XP on MacIntel using the recently revealed Narf hack?
    2003-05
    Charlotte, NC
    398
    Here's a zipped Quicktime file of both laptops rendering. 300dpi, 1600x1600. Took around 2 minutes on the MacBook and around 3:30 on the IBM.
    The friend with the MacBook has signed up on AUGI. Works for a Mac-centric firm here in Charlotte. He'll monitor the thread for any technical questions.
    -Phil
    2006-03
    Charlotte, NC
    10
    Quote Originally Posted by irusun
    Yeah is was the Narf hack from onmac.net. It took a few tries to get it XP to install. (Back up your data and wait untill you get XP running before you copy it back over.)
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,611
    VERY interesting. Please update us when you get those graphics drivers hacked.
    Member lennox.boyd's Avatar
    2005-08
    Dingwall
    4
    Great work Phil. now the really cool thing would be to run Revit on OSX
    2006-03
    Charlotte, NC
    10
    Quote Originally Posted by Andre Baros
    The screen graphics are slow but not that much of an issue. The MBPro was faster rendering than an R-serise ThinkPad. The bigger issue right now it the fan control. Either it's all on or all off. I'm waiting for a driver for that.
  1. Is a graphics card need for Revit when the CPU is an intel i7 ?
    By nicholassocrates789477 in forum Hardware
    Last Post: 2012-07-25, 03:35 PM
  2. AutoCAD running slow on HP intel core 2 duo E6600
    By kwong in forum AutoCAD General
    Last Post: 2007-04-11, 10:51 PM
  3. Revit and Intel Core 2 Duo Processors
    By saeborne in forum Revit - Hardware & Operating Systems
    Last Post: 2007-04-06, 01:46 PM
  4. Running CAD on Intel based Macs
    By jamesvue1981 in forum Hardware
    Last Post: 2007-03-26, 04:55 AM
  5. Replies: 1
    Last Post: 2006-06-20, 03:17 PM
