Thread: Beginner Question - Wall Joins, Wall Ends
    2006-03
    16
    Default Beginner Question - Wall Joins, Wall Ends
    Hi, I'm new to this Forum. My name is Joe and I work in Manhattan. (I'm also a novice revit user) I have a few basic question in regards to wall joins which I would really appreciate any suggestions.
    Is there a way to control the end conditions of a wall, without it meeting another wall. Can you define an angle or reference plane that it aligns to? We have a building where none of our wall joins are 90 degrees.
    These conditions create complications between windows and walls in two places so far.
    1.) I'm not sure how to resolve the curtain wall/generic 12 inch wall corner condition. See image 3.
    2.) "" the ribbon window 12 inch generic wall condition. See images 2.
    In addition, is there a way to control wall ends? We have an iffy condition where we have a cantilever with a curved wall bellow it.
    How would you recommend modeling these conditions? Should my Ribbon windows be curtain walls with mullions or standard window frames? How do I get my ribbon window to effectively turn the corner?
    Thanks in advance,
    -Joe
    I could stop if I wanted to mibzim's Avatar
    2005-06
    Brisbane, Australia
    260
    Default Re: Beginner Question - Wall Joins, Wall Ends
    Taken a while for ppl to respond to this one, but i think its because we either not sure what you are after or revit can't do it. There isn't a lot of control over wall joins apart from the wall join tool and dis-allowing joints. Maybe post an image of what you are after?
    100 Club ejc's Avatar
    2001-04
    125
    Joe,
    First, welcome to Revit, and may you never have to look back!
    I have to agree with the previous post, in that I am not sure exactly what you are after.
    Here are a couple of helpful hints.
    1. When working with curtain walls, be prepared to disallow the curtain wall join. It tries to help by jumping into an adjoining wall.
    2. The best way to place a door in a curtain wall is to replace the panel in the door location with a generic wall, of the same thickness as the mullions. Then insert a standard door into that wall. (ex. 5'-0" wide wall for a 5'-0" wide double door). This allows the curtain wall door to be scheduled.
    Enjoy,
    ejc
    All AUGI, all the time gbrowne's Avatar
    2004-03
    Glasgow, Scotland
    579
    1: There are a few ways around this, you could either do an in place wall and shape it any way you like, or use a thinner wall and do the shape, or add a profile, or completely ignore it and cheat by using the linework tool.
    2: Curtain walls take a bit of effort to get to grips with, but they work well and there is a corner mullion which will do the trick.
    As they say "draw it like you build it".
    And curtain wall doors can be scheduled/tagged. Use the tab to consecutively select items and alter the type to the door family. I recommend you do the curtain wall tutorial as it had me totally confused as well.
    Alternatively you could meet up with the freedom tower team who are also in Manhatten and ask them, cos they would appear to be the pacesetters with Revit right now.
    Best o' luck!
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    Quote Originally Posted by jalexander.108656
    -Joe
    If you have wall ends that are joining other walls that you do not want to join to, select the wall and right click the end grip and dissallow the join.
    If you want to sculpt the end angle of an unjoined end you can use an in place void to cut the wall end to the angle you need.
    Also wall corners will react differently when you use the "Edit Wall Joins" tool and set the corner to butt, mitre, or square.
  1. 2012: How to extend top or base of a wall layer when the wall ends wrapped and not joined to other wall?
    By architekz.188213 in forum Revit Architecture - General
    Last Post: 2013-01-24, 08:46 AM
  2. Replies: 0
    Last Post: 2013-01-15, 10:12 PM
  3. Align ends of wall sweeps with profiled wall
    By detroit.architecture in forum Revit Architecture - General
    Last Post: 2010-10-19, 02:33 AM
  4. Wall based sweep not cutting at wall joins
    By leeba in forum Revit Architecture - General
    Last Post: 2010-07-12, 02:51 PM
  5. Wall joins with differing wall heights
    Last Post: 2005-12-06, 02:51 PM
