Thread: Hidden lines in 3d Views keep hidden when plotted
    I could stop if I wanted to Damo's Avatar
    2004-05
    London, UK
    326
    Default
    I would like Revit to keep walls I’ve hidden in a 3d view to remain hidden when I plot.
    I have generated an axonometric view of my project (Revit 6.1), showing all
    elements. Wanting to create a cut-away view, (not by having a clip plane as this would generate strange cuts on walls etc ) I used the 'VIEW' drop-down menu,
    selecting Hide/Isolate and then picking the various walls, floors etc I
    wanted to temporary hide. On the sheet this looked exactly as I wanted it,
    but the plot brought back all the items I'd hidden!
    Also, can we please have an easy way to hide a whole floor / level and everything above, or a section line and hide everything forward of the section line, in the 3D view, and keep them hidden when plotted?
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    Default Re: Hidden lines in 3d Views keep hidden when plotted
    with worksets you could do the first thing you want. It's a clunky work-around tho.
    with section boxes you can do the second right now. But that's only with shaded views.
    2004-05
    London, UK
    326
    It's taken me a bit of time to get the solution, but my Revit tutor told me the solution today.
    Looking at my axonometric, get into the View Properties dialogue box. Near the bottom, there is a parameter 'Section Box', check the tick box. Then in the axonometric view you have a box around your model. Each of the 6 blue dots control the 'cutting plane' which will slice through the model. ( I found this would only show a result if the model was 'SD' shaded)
    To make the section box invisible, uncheck the Crop region Visible.
    Damian
    (Forum Administrator, you might want to remove this thread from the WishList)
  1. 2012: Plotting isometric views with hidden lines
    By JLitke@PLSI in forum AutoCAD Plotting
    Last Post: 2014-02-06, 07:23 PM
  2. Replies: 3
    Last Post: 2011-01-31, 04:15 AM
  3. Foundations as Hidden Lines in Elevation Views
    By bclarch in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-06-30, 03:23 AM
  4. 3D Plotted output - Hidden lines and Shade view
    By dbrach in forum AutoCAD General
    Last Post: 2006-03-13, 11:20 AM
  5. Topo lines are hidden in hidden line view b/t demo & new
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-12-12, 11:33 PM
