Hi,
I am looking for a Program which can export the general text, attribute data, tags etc from drawings to excel and back from excel to autocad drawings. The key things are I want to export the data from single or by selecting multiple drawings. after the data is exported, basically looking at one drawing data in one sheet i.e. 10 drawings data in 10 sheets of one single excel file. Then i will be doing some changes in the values and want to import back the changed values in the same fashion as Export. The export attribute function when selected from the Drop menu exports only in .txt fashion and when I use EATTEXT option it does not arrange in the order i want which is creating problems, and still after I change the values in .xls file and import back it does not work properly.
Looking for a early response.
Regards
