Results 1 to 10 of 15
Thread: How to draw a Coordinate system?
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Question How to draw a Coordinate system?
    Anyone here ho knows the command to draw a Coordinate system?
    I already searched the help-file of AutoCAD & this Forum for "Coordinate System, Raster, and Grid" with no results.
    I know there is a command in AutoCAD r2004 ADT. Problem is, I don’t have this version anymore at my disposal and my mind just letting me down.
    Ore could it be that this command is gone in AutoCAD r2006...
    2003-11
    Blue Springs, Mo.
    117
    Default Re: How to draw a Coordinate system?
    Unless I'm reading your statement wrong, you don't draw a coordinate system. You draw from a pre determined coordinate system. ie. x-5000, y=5000, z=0. Is your project already on a coordinate system?
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    As Mike stated you don't draw a coordinate system. If you trying to draw a coordinate grid I do not know of any single command in AutoCAD that will do that.
    I would draw one line for each axis of the grid then use the array or offset command to generate the remaining lines.
    Jeff Paulsen
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,293
    Thumbs up Re: How to draw a Coordinate system?
    Have you gotten any more info on this?
    Your coordinate system is where your working.
    The default is the "World Coordiate System".
    You can change it by using the command "ucs".
    In that, you can create a new one.
    It gives options like using 3 points, assign a new origin, angles etc.
    A related command is "ucsicon" which controls where the ucsicon is.
    NoOrigin takes it off the assigned 0,0,0 coordinate.
    Ted
    2006-02
    Belgium
    133
    Quote Originally Posted by jpaulsen
    I would draw one line for each axis of the grid then use the array or offset command to generate the remaining lines....
    Just like me at the moment.
    In AutoCAD r2004 there was a command to draw a pre determined coordinate system that lets you easy change and add extra axis.
    I'm trying to retrieve an old copy of it to check it out.
    I could stop if I wanted to johan d's Avatar
    2006-01
    Belgium
    287
    maybe you mean grid on/off (F7)
    But that are points and no lines...
    2006-02
    Belgium
    133
    That’s right, points and no lines. Also there are no numbers/characters that says this is ‘axe A’ and this is ‘axe 1’ and you can’t plot/print it.
    2006-01
    Belgium
    287
    Tools - drafting settings... from there you will find it
    2006-02
    Belgium
    133
    Tools – Drafting Settings …. (AutoCAD 2006)
    Mmmm, Aha, Format – Drafting Settings (AutoCAD 2006 ADT)
    Nope, it’s just the Grid here. Or there’s a prob with my installation here.
    2006-01
    Belgium
    287
    Explore grid & snap in your acad helpfile
  1. Replies: 0
    Last Post: 2011-01-25, 04:59 AM
  2. Creating new coordinate system
    By kevinb.267013 in forum AutoCAD Map 3D - General
    Last Post: 2010-10-25, 08:00 PM
  3. coordinate system problem
    By bhron_d in forum AutoCAD General
    Last Post: 2010-05-21, 02:13 PM
  4. Coordinate System
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2006-06-21, 05:05 PM
