Results 1 to 6 of 6
Thread: Can a sweep follow a 3D Path?
    100 Club ejc's Avatar
    2001-04
    125
    Default Can a sweep follow a 3D Path?
    Is there a tool that acts like a sweep, but with a path that goes along the x,y and can change in the z, and continue on?
    thanks,
    ejc
    2005-03
    70
    Default Re: Can a sweep follow a 3D Path?
    I think I can answer that question. There isn't.
    It's one of the things we've been longing for because it would allow us to do sidewalks and curbs a lot more easily. Unfortunetely... we don't have such an option. Let's wait to see what revit 9.0 brings...
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    What you can do though is select edges in 3D. So if you make say void you can then select the the edges as the path of the sweep.
    All AUGI, all the time archjake's Avatar
    2003-07
    Tucson, AZ
    531
    Quote Originally Posted by Elmo
    Yes, This is a very slick trick! I think it was Phill Read who did some nice massing families like this. Parametric star shapes, etc.
    Revit Arch. Wishlist Mgr. Wes Macaulay's Avatar
    2003-05
    Vancouver, BC CANADA
    3,348
    You can also use reference lines in any XYZ plane to use as a sweep path.
    But Revit need a lofting tool since we can't control what happens to the profile as it sweeps along the path. I often don't get the results I want.
    2004-06
    Memphis TN area
    7,048
    I think we just need more solid and void modelling tools. I know FormZ has tools specifically to create spiral-shaped solids and voids, and a few others that I can't remember off the top of my head.
  1. Host Sweep which can Follow sloped wall tops
    Last Post: 2010-03-12, 05:46 AM
  2. 2010: Fillet Curve in a Sweep Path to follow as I adjust an Angle?
    By snowyweston in forum Revit Architecture - General
    Last Post: 2010-01-22, 04:08 AM
  3. Follow a Path
    By Rick Houle in forum Revit Architecture - General
    Last Post: 2008-06-20, 09:11 PM
  4. sweep profile - always vertical to the sweep path
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2006-11-02, 06:14 PM
  5. Sweep to follow a gable
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2004-09-03, 04:36 PM
