How would you do this in Windows 7? Apparently, windows explorer in Win7 doesn't give you any "apparent" options to do anything with anything. Maybe I just need a Windows 7 for dummys book or something.
No, I think the friendly interface has disappeared. However, you can add it by the registry.
The below sample is for AutoCAD 2010. Change the "18" to "17" for AutoCAD 2007-2009. Change the text in green to match your file location and name.
Code:Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\AutoCAD.Drawing.18\shell\Open_as_Read_Only] @="Open as Read Only" [HKEY_CLASSES_ROOT\AutoCAD.Drawing.18\shell\Open_as_Read_Only\command] @="\"C:\\Acad\\Cache\\Open DWG as Read Only.cmd\" \"%1\""
R. Robert Bell
Design Technology Manager
S P A R L I N G
Opinions expressed are mine alone and do not reflect the views of Sparling.
R. Robert Bell
S P A R L I N G
v good dear nice sharing keep it up.
JAMAL
Great tip, but the only reason i wanted to open a DWG in read only is when the file isnt mine to edit, i just wish to review it. If the file is currently opened by another user, this batch file doesnt work - i get a cmd message saying "The process cannot access this file because it is being used by another process"
Obviously i can use Autocad's open read only way, but i was hoping this could be done by explorer.
Any help/suggestions?
edit- Im using winXP SP3 and the files are located on a server.
In that case...
Save this to OpenReadOnly.vbs anywhere, say drive C.Code:On Error Resume Next dim cmd_arg set cmd_arg=wscript.Arguments Dim acadApp Set acadApp = GetObject(, "AutoCAD.Application") If Err Then Err.Clear Set acadApp = CreateObject("AutoCAD.Application") End if acadApp.visible=True acadApp.WindowState = 3 acadApp.Documents.Open cmd_arg(0), True
Then the command under Application used to perform action: would be
wscript.exe C:\OpenReadOnly.vbs "%1"
Tested on local files in AutoCAD 2008 XP SP3 Platform. Please try if it will work on other versions and network files.
Shielbern Bolalin
Architectural 3D Renderer
“A clever person solves a problem. A wise person avoids it.”
1879-1955
