Thread: Keeping layerstate when Binding Xrefs
    2006-02
    Research Triangle Park, NC
    62
    Default Keeping layerstate when Binding Xrefs
    Is there a way to keep what I see on my screen in layout view when I go to bind(Insert) the attached xrefs?
    What is happening is I bind the xrefs and the layers turn off and on with no input from me!
    Tim
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Keeping layerstate when Binding Xrefs
    If you have duplicate layer names, the insert inherits the state of those layers when doing an insert of an xref, instead of bind. The bind keeps the unique layer names, thus maintaining the layer state.
    2005-06
    in the upper right corner
    3,508
    Thumbs up Re: Keeping layerstate when Binding Xrefs
    As you probably know when you "bind" (not bind insert) it gives you funky layer names like "base$0$wall". These can be renamed using the "rename" command and wildcards. I actually read a string on this last week somewhere in this forum.
    "rename"
    <xref-layer name>$0$*
    (to)
    <new prefix>*
    Works great!
    Ted
  1. Dissapearing Xrefs when binding
    By john.panda in forum AutoCAD General
    Last Post: 2010-08-11, 03:00 PM
  2. Binding xrefs using ABS2006
    By kwortman118893 in forum Software
    Last Post: 2008-07-11, 07:20 PM
  3. Etransmit not Binding Xrefs
    By cmolina in forum AutoCAD General
    Last Post: 2007-04-30, 08:38 PM
  4. etransmit not binding xrefs
    By hostetterkl in forum AutoCAD General
    Last Post: 2005-06-02, 11:48 PM
  5. Binding Xrefs
    By mike.49387 in forum AutoCAD General
    Last Post: 2004-07-12, 03:10 PM
