Results 1 to 10 of 11
Thread: C3D and Vault
    100 Club Phil Ferguson's Avatar
    2002-08
    Buckeye State
    137
    Question C3D and Vault
    All right...I clipped this from the Civil 3D General Forum and it's part of Marks response to another question but this part caught my attention and I thought it deserved another thread.
    Quote Originally Posted by MHultgren
    <snip>... Wait till you see 07 though! Since they have announced it, I am really excited about the Vault with 3D.<snip>
    I am not familiar with Vault and have not had the time (yet) to research. What functionality does this present and what type of tools will we be able to leverage?
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,381
    Default Re: C3D and Vault
    Got your attention huh? Essentially the Vault is a Doc. Management System for C3D project data so you can save the data to the 'Vault' so everyone has access. One person can 'Check out' the data for Read-Write and everyone else can still get Read access to the data. You have a choice now, save the entire project in one file, or in a library that others can access.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2005-10
    80
    But the demonstrations i have seen of vault it is more of a File managements system and will do very little to help bring back "project" type file usage and sharing of project data. I could be wrong, and i could have been shown differently that how it is intended to be used with C3D
    Clyde, NC - USA
    1,381
    That is exactly what a DMS is. Kind of like a librarian. One person can check out the data with the ability to Write or overwrite it while everyone else who checks it out can read the data and be notified if\when there is a change to it so they can reload it into their files. Similar to the Multi-user capabilities of LDT. Once a Lock was placed on a file (alignment.mdb for example) only that person could make changes to that database. Others could still Read the data, but couldn't create a new alignment while the lock was placed by someone else. The Vault just gives us that capability with 3D.
    Mark Hultgren
    Just a Lurker
    Blog
    Socializing??
    2005-10
    80
    But is the alignment still contained inside the "working" drawing? so that only one person can be in the "working" drawing? Maybe i am missing the concept of how this is supposed to be like LDT. Because LDT held the alignment, point data, etc. outside of the drawing.
    Clyde, NC - USA
    1,381
    With the Vault, you have a choice. You can save the data inside the dwg or you can save the design data in the vault but the intelligence and graphics are still maintained from what I understand so far. Check out some of the threads in the Revit and Viz forums regarding the Vault for more information.
    Mark Hultgren
    Just a Lurker
    Blog
    Socializing??
    Active Member melanie.santer's Avatar
    2005-10
    Orange County, CA
    67
    All of the design data is stored in the drawing and the drawing is stored in the Vault. Although you do have the ability to check in or check out intelligent objects such as your alignments.
    Make sense?
    Georgetown, TX
    3
    For a really good explaination, see Scott McEachron's blog...
    http://c3dpavingtheway.blogspot.com/2006/04/vault.html
    2005-03
    50
    As Melanie said, although it appears the data just resides in the Vault, the data really resides in the drawing. When you access an alignment from the Vault, you are really opening up the drawing that contains that alignment.
    Check out my blog site that lists a proposed workflow for Vault... latest article. This should help.
    http://digginginc3d.blogspot.com/
    Danny Counts
    L.A. CAD, Inc.
    2003-03
    Omaha, Nebraska
    18
    Data reference information is stored in a .xml file that is put in a vault "project" by default. If your curious you can go into vault explorer and look at it. As Danny said all the data is stored in its original drawing file. This is actually quite handy if you need to take a file home to work on. No need to copy the entire project anymore...
    The project.xml file will look similar to this:
    - <ProjectInfo>
    <ProjectDesc>Default templates</ProjectDesc>
    - <Shortcuts>
    - <Shortcut name="$Road ShowGrading-01.dwg:eg">
    - <Criteria>
    <File name="$Road ShowGrading-01.dwg" />
    <Object type="AeccDbSurfaceTin" useType="0" name="eg" useName="0" version="1" useVersion="0" handleLow="541893" handleHigh="0" useHandle="-1" />
    <DisplayProperties layer="0" useLayer="0" color="1" useColor="0" lineType="ByLayer" useLineType="0" lineWeight="0" useLineWeight="0" />
    <Vault sourceDrawingMasterFileId="253" parentHandleHigh="0" parentHandleLow="0" objectDescription="" />
  1. Vault & Pro/E
    By virginiap in forum Vault - General
    Last Post: 2010-09-17, 07:29 PM
  2. Vault- attach from vault command not there
    By jenniferchavez in forum Vault - General
    Last Post: 2008-12-10, 06:45 PM
  3. Replies: 8
    Last Post: 2007-05-14, 06:44 PM
  4. Replies: 0
    Last Post: 2006-09-18, 03:55 PM
